402 LS2 FI Long block, Fuddle LS1 4L80E Converter, D&D built T56, Stock T56
Old Sep 19, 2008 | 09:12 AM
ozws6's Avatar
Default 402 LS2 FI Long block, Fuddle LS1 4L80E Converter, D&D built T56, Stock T56
402 LS2 short block assembled by Texas Speed
Callies Dragon Slayer crank
Lunati Pro Mod rods
Mahle -32cc FI pistons pn#LS1105000I32 (8.3:1 compression)
ARP main stud kit
ARP head stud kit
Comp 232/228 0.595/0.588 115 LSA custom turbo cam
Comp pushrods 7.40"
Comp OE lifters
SLP oil pump
LS2 timing set
Front, rear, and valley covers
AFR 225cc Heads pn #1630, 72cc chambers, 8019 spring upgrade Sold
All above have 4200 miles on them, only 1300 miles where with the turbo kit installed. Motor is in excellent condition. NA it made 450 rwhp, at 15 lbs of boost on a conservative pump gas tune, 800 rwhp. My reason for selling is I'm planning to build a LSx block, 6 bolt head motor this winter.
Fuddle LS1 4L80E converter, Elite series 3400 stall, like new with 500 miles use. Does not require crank spacer to install, direct fit. Sold
D&D built LS1 T56, rated at 1200 ft/lbs, G-force gearsets and shafts, upgraded sliders, steel 3-4 shift fork, 30 spline output shaft with slip yoke, cooler bungs added to case. Trans is like new and only has 3500 miles on it.
Stock T56 out of a 01 F-body, 22k miles, excellent condition. Can include stock LS6 clutch with 22k and slave cylinder for an additional $.
Old Sep 19, 2008 | 02:42 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Fuddle LS1 4L80E converter, 3400-3600 stall, like new with 500 miles use. Does not require crank spacer to install, direct fit. Stalled for high hp (700-800 rwhp) FI motor.
$400
PM me more info please.
Old Sep 19, 2008 | 03:16 PM
WutupYo's Avatar
willing to let JUST the block go?
Old Sep 19, 2008 | 03:18 PM
ozws6's Avatar
$400
You got a PM John. Thanks.
Old Sep 19, 2008 | 03:19 PM
ozws6's Avatar
I'm willing to sell just the assembled short block, but not just the bare block.
Old Sep 19, 2008 | 03:22 PM
WutupYo's Avatar
how much for the short block?
Old Sep 19, 2008 | 03:49 PM
ozws6's Avatar
You got a PM!
Old Sep 20, 2008 | 02:38 AM
V8_Club's Avatar
Will the motor work with a blower car ? Or would we need to swap out the cam ? Also will Texas Speed or a forum vendor be able to inspect the same ?
Old Sep 20, 2008 | 06:21 AM
ozws6's Avatar
The motor is 8.3:1 compression so it is setup for running boost, either turbo or supercharger. For a supercharged setup I would probably change the cam so it's not a reverse split.
Old Sep 20, 2008 | 05:46 PM
Vette&CobraGuy's Avatar
Which relucter set-up is this?
Old Sep 20, 2008 | 08:05 PM
ozws6's Avatar
It's a 24 tooth wheel.
Old Sep 21, 2008 | 08:45 AM
ozws6's Avatar
Did a leakdown test on the long block last night as I've had a few inquire into #s. The test was done with the engine cold as it's out of the car.
Cylinder % leakage
1 8%
2 5%
3 9%
4 6%
5 10%
6 5%
7 6%
8 8%
As you can see the leakdown #s are pretty good for a loose FI motor. Here are a couple pics of the longblock and bottom end:
Old Sep 21, 2008 | 08:17 PM
helicoil's Avatar
so this is a std. 4.00" bore block? how much for the short block with no cam.
Old Sep 21, 2008 | 09:16 PM
ozws6's Avatar
Block is a 4.000" bore. You got a PM on the shortblock.
Old Sep 21, 2008 | 09:49 PM
jason02Z's Avatar
will you sell the heads separate and how much?
Old Sep 21, 2008 | 11:14 PM
boba17's Avatar
PM sent
Old Sep 22, 2008 | 01:02 AM
98cobrakillata's Avatar
Interested in stock t56.
Does trans come with bellhousing?
Where in MO are you located?
Old Sep 22, 2008 | 08:16 AM
HotRod68Camaro's Avatar
interested in the short block
Old Sep 22, 2008 | 08:35 AM
ozws6's Avatar
All questions and pms have been answered in pms. Thanks!
Old Sep 22, 2008 | 01:29 PM
ozws6's Avatar
Sale pending on the D&D built T56. Thanks!
