non-LSX Parts For Sale SBC, LT1, V6, etc.
FS: LT4 KS, 1LE Elbow, PCMs, M6 Harness, Bullet Mufflers, E-cutout, Cat, gaskets, etc
Old Oct 8, 2008 | 01:37 PM
Tireburnin's Avatar
Default FS: LT4 KS, 1LE Elbow, PCMs, M6 Harness, Bullet Mufflers, E-cutout, Cat, gaskets, etc
FS: LT4 KS, 1LE Elbow, PCMs, M6 Harness, Bullet Mufflers, E-cutout, Catalytic converter, Intakes, Throttle Body, MAF, Alternator, Starter, LS1 Gaskets, LS1 Head bolts, 02 Sensor etc
MORE PICTURES - http://picasaweb.google.com/snvent/B...y=X2BlklNDEi0#
All prices are OBO and don’t include shipping unless otherwise noted. If the item is over $100, please include 3% for paypal fees unless you pay by Paypal E-check which limits the fee to $5. I’ve sold over $20,000 in parts on this board, LS1tech and Ebay without a single complaint. I can provide feedback info for all places. If you have any questions please feel free to post here or email me at snvent(at)gmail.com
LT4 Knock Sensor - $25 + shipping SOLD
This came out of my car and a car I am parting out. I am swapping to an LS1 and have no use for it.
1LE Intake Elbow - $50 + shipping SOLD
The elbow is in good condition with NO tear, rips or holes. Includes the IAT sensor. These elbows tend to go for $70+ on Ebay.
LT1 OBD1 PCM - $55 + shipping
Auto PCM – This unit came out of my personal 94 Z28 and has a tune for a 355 heads/cam nitrous car in it. It is programmed for a th400 and worked fine when removed for my LS1 swap.
94-95 LT1 PCM Engine Harness - $139 + shipping
This harness came out of a 94 Z28 I am parting out and is in good stock condition. There are no burned wires or cut plug ends. A couple of the plugs are missing the plastic lock clip, but they were plugged in an the harness was functioning well before removal. (Harness only)
Bullet Mufflers (for off the headers) w/ turn downs - $39 + Shipping
These were made for and bolted up to JetHot long tubes. The driver’s side has a bung for a wideband sensor. Both are 3” in and out bullets with turn downs. The bullets include copper gaskets and grade 8 bolts to attach to the headers. Copper gaskets can be reused 100’s of times and the grade 8 bolts won’t break or shear under routine removal. These are loud and are intended for a race car. The driver’s side bullet is clearanced to fit well under the car.
Stock LT1 Throttle Body - $20+shipping SOLD
Came off a 94 z28 that I’m parting and includes bolts, IAC and TPS sensors. Was functioning fine before removal.
Stock LT1 starter - $5 + shipping SOLD
Worked fine before removal. Cranked well when hot. Unknown miles but worked well.
Stock LT1 Coil and ICM - $14 + Shipping SOLD
Newer stock coil and ICM. Came off a 94 z28 that was running well before removal. The coil was replaced in the last 10k miles with the opti.
Stock 98 LS1 Intake, TB, Injectors, Fuel Rails - $85 + Shipping
This LS1 intake was removed from a 98 formula with 100,000ish miles. It is complete except for the sensors and has the 28lb injectors, stock throttle body, fuel rails and intake.
Stock 94 LT1 Intake, Injectors and fuel rails - $69 + Shipping SOLD
This intake is stock and came off a running 94 z28. Includes stock injectors, fuel rails, EGR and a MAP sensor. Ran fine and would be good for porting and parting out. The car had 90K miles on it when pulled apart.
Stock (Replacement) LT1 Alternator - $18 + shipping SOLD
This is a recently replaced LT1 alternator with less than 10K miles on it. It was working well and is a 108 amp unit. Would make a good replacement for someone.
Ported LS1 MAF - $41 + shipping
This MAF came off a 98 Formula that I parted out. It has ported ends and is de-screened. The car was running fine until it spun a bearing. My LS1 swap will be run in SD, so I have no use for it.
Stock LT1 MAF - $41 + shipping SOLD
This MAF came off a 94 Z28 that I am parting with around 90k miles. It was working fine and the car was running before removal. The MAF is completely stock and untouched. It includes the screen.
DMH Electric Cutout - $109 + shipping
This cutout was tested and is functional. It is a 3” electric cutout that has no manufacturer markings but is so close in build to a DMH cutout, that I feel confident calling it such. The cutout comes with the harness and operating button. Works great and shipping should be about $12 to anywhere in the US/Canada.
98 LS1 PCM & 98 M6 Engine Harness - $290 + Shipping (Or $225 Harness & $135 PCM if separate) SOLD
Both came out of a 98 Formula with 100,000ish miles. The harness is untouched and looks to have all of its plugs in good condition. The PCM was working well and the car was running before it was removed. I thought I needed it for my LS1 swap, but I am going to a FAST setup and no longer need it.
NEW GM 98 LS1 Valve cover gaskets (2) - $20 for both + shipping
These were purchased for a rebuild that I never did. They are brand new gaskets in the packaging. They were $35ish when I bought them. Part #12556429
NEW GM LS1 Exhaust Manifold Gaskets (2) - $15 for both + shipping
These were bought for a rebuild I never did. They are new in the package and cost me double this amount. Part #12600530 I think (see picture)
(2) NEW GM LS1 Head Bolt Sets - $35 for both or $18 each + shipping
Brand new LS1 head bolts for pre 2004 blocks. Only removed from the box for pictures. Part #12498545
Newer Bosch LT1 02 Sensor - $12 + shipping SOLD
I bought this sensor right before I tore down my LT1. It has less than 100 miles on it and was used on my track only car. I was trying to track down an 02 issue so I bought a new one. This sensor doesn’t even have build of on the surface from use. Virtually new.
Stock LT1 94-95 Single Catalytic Converter - $70 + shipping
This came off the 94 Z28 I am parting and has a good core. It has been modified to put a set of AS&M headers. It could easily be welded into a stock or other y-pipe. The core looks good and has a recycling value approaching what I’m offering it at.
Old Oct 8, 2008 | 05:50 PM
Tireburnin's Avatar
Updated the list. LT1 M6 PCM is sold.
The auto one is still available and I can load another tune into it if that works for anyone. (Not tuning just another stock tune)
Old Oct 9, 2008 | 10:35 AM
Tireburnin's Avatar
Responded to PMs. TTT
Old Oct 10, 2008 | 12:31 PM
Tireburnin's Avatar
Updated the list for sold items. TTT
Old Oct 11, 2008 | 12:24 PM
Tireburnin's Avatar
TTT for the weekend
Old Oct 13, 2008 | 05:47 PM
Tireburnin's Avatar
TTT for today. Prices are OBO
Old Oct 14, 2008 | 12:44 AM
halucinator's Avatar
$20+shipping to 46706 for KM?
Old Oct 14, 2008 | 10:43 AM
Tireburnin's Avatar
That would be fine. I will get a quote and PM you later today.
Old Oct 14, 2008 | 11:37 PM
Tireburnin's Avatar
Responded to all PMS and lowered some of the prices. TTT
Old Oct 15, 2008 | 09:53 AM
wickedformula's Avatar
still have the knock module?
Old Oct 15, 2008 | 10:20 AM
Tireburnin's Avatar
I have it as pending because I have an excepted offer, but no cash yet because they are paying by Money Order.
Check back in a few days and I will know for sure.
Old Oct 15, 2008 | 05:01 PM
Tireburnin's Avatar
Old Oct 16, 2008 | 01:38 PM
Tireburnin's Avatar
Bump for today
Old Oct 17, 2008 | 11:47 AM
Tireburnin's Avatar
TTT - responded to PMs
Old Oct 18, 2008 | 12:18 PM
Tireburnin's Avatar
Bump for the weekend
Old Oct 20, 2008 | 02:45 PM
Tireburnin's Avatar
TTT for today
Old Oct 22, 2008 | 10:15 AM
Tireburnin's Avatar
One more before I make a new post. TTT
Old Oct 28, 2008 | 05:33 PM
YORK_MUSTAINE's Avatar
whats brand name for the bullets?
