02-14-2008, 02:44 PM
#1 | | 10 Second Club
| Can I get into the 9's? My question is if I spray another 50 shot do you guys think I will atleast get a 9.9999.......lol! Cars ran 10.37 @130 on a 200 shot. I'm thinking of doing a 250 shot to try to get a 9 sec pass. Do you think it will be enough to get me there?
__________________ 2000 Z28 - 10.37 @ 130.2 Mods: Hooker LT's w/X-Pipe | LS6 Intake | ASP Pulley | Shaner S2 TB | QC 3200 | TSP Lid | 3.42's |TNT F2
TSP 231/237 | TH-350 | 42lb Injectors | Stock Heads | Stock 10 Bolt | Free Mods... |
02-14-2008, 07:09 PM
#2 | | TECH Apprentice
| i doubt it, it should get you right there, but i dunno about 9.999
thats purely my guess though |
02-15-2008, 11:22 AM
#3 | | TECH Addict
| I would think so, assuming the car hooks right ,I've gone as fast as 10.1@130, I have a buddy that's gone 10.00@129, so you're close mph wise, with the extra 50 hp and if the car hooks like it should, you should get there.
__________________ Black 1998 Camaro Z28 Currently under construction tin can with 4 wheels
Email:CHRISTOPHERMORALES@HOTMAIL.COM www.fquick.com/RAGEN98Z28
"Friends don't let friends drive imports" |
02-15-2008, 12:44 PM
#4 | | 10 Second Club
| Thats kinda what I was thinking. Cars got as fast as 131 MPH. As far as hooking it hooks up good I think thats whats going to make it or break it. On my 10.37 pass car 60ft was a 1.47. A few passes after that a pulled off a 1.41 60ft but had to let off so did get a clean pass. IMO if I do the 250 shot and can pull another low low 1.4x 60ft I should be right there!
02-17-2008, 01:02 AM
#5 | | Banned
| You on the stock shortblock? |
02-17-2008, 01:17 AM
#6 | | 10 Second Club
| Quote:
Originally Posted by stainless40cal You on the stock shortblock? | No, I'm running a forged LME 347........
02-17-2008, 01:21 AM
#7 | | 10 Second Club
| Interesting.... I, too want to reach this goal, 9.999. |
02-19-2008, 11:51 AM
#8 | | Staging Lane
| Are you full weight?
__________________ 2000 Z28 Camaro M6
Under a recall by me |
02-19-2008, 12:02 PM
#9 | | 10 Second Club
| Quote:
Originally Posted by Kuhnstyle86 Are you full weight? |
Car weights about 3600 lbs. with me in it!
02-19-2008, 12:07 PM
#10 | | Staging Lane
| dump weight
03-10-2008, 03:18 AM
#11 | | TECH Apprentice
| You Need The Suspension Setup Right
__________________ 1999 Ford Lightning. 684 rwhp & 925 rwtq. 10.40@129
1995 Z28 Tuned by James@RWTD. rwtd.com Mobile,Alabama. 520 rwhp 490 tq N/A through a 12 bolt and 4L80e. Nitrous direct port completed! 408 Iron block swap with 4L80e completed.
10.55@134 N/A 3938lb car with driver.
Nitrous times.....Well take a guess
"have you ever noticed anybody going slower than you is an idiot, and anyone going faster than you is a maniac?" -George Carlin |
03-10-2008, 06:44 AM
#12 | | Teching In
| if you don't mind me asking, what kind of times are you running on motor? I have a VERY similar setup as yours and I have set my sights on a 9.99 too. |
03-12-2008, 02:42 AM
#13 | | TECH Enthusiast
| are you still on a 10 bolt?
__________________ 98 Z28,408-E.T 255's,big cam,sheetmetal intake,wilson 105mm,1 7/8 LT's,3" td's,moser 12 bolt,asp ud pulley,spohn adj ta,spohn lca's,TH400,3600 stall,1 nx kit,
5 stars with 26" et streets
draglites with 28" et drags
almost there |
03-12-2008, 03:05 AM
#14 | | 10 Second Club
| Quote:
Originally Posted by SILVERZZ28 You Need The Suspension Setup Right | I have bone stock suspension! I just recently added an Eibach Pro kit to the front and thats about it. Everything else are the stock parts that came on the car from the factory. Quote:
Originally Posted by 20lbbooster if you don't mind me asking, what kind of times are you running on motor? I have a VERY similar setup as yours and I have set my sights on a 9.99 too. | Cars done a best of an 11.60 on motor! But usually consistent 11.70's. Quote:
Originally Posted by smok'nZ are you still on a 10 bolt? | Yes, I am still running my 10 bolt with 3.42's!
03-18-2008, 01:21 AM
#15 | | TECH Addict
| Needs gear...
03-23-2008, 12:57 PM
#16 | | TECH Enthusiast
| and suspension
__________________ Tow- 02 Dodge Cummins dually
Go- 01 TA complete new setup coming. going almost full drag. forged stock cubes, victor Jr., TH350, 4k stall, 9", and some funny stuff
Project X- 06 Ex-cab Z71 just a little boost |
03-24-2008, 09:17 PM
#17 | | 10 Second Club
| my car runs 1090's what should it run on a 200 shot?
__________________ 2000 Camaro SS (red) M6
all stock, daily driver
13.21 @ 110.08 MPH (steet tires) 2000 Camaro SS A4 (Bright Atlantic Blue)
3.73's M/T's
10.96 @ 123 6.96 1/8 @ 98 1.52 60' N/A
N20- 6.29 @ 112 1.41 60' on DR's |
03-26-2008, 09:08 AM
#18 | | On The Tree
| I would look to lose 200lbs and trick out the suspension and you should see 9s without touchin the motor. |
04-05-2008, 05:45 PM
#19 | | Staging Lane
| buy yourself some suspension and some 4.10s, and you should be able to hit 9s.
__________________ 94' GT 5 speed; 88k miles-
Mods: Flowmaster Cat-back, Underdrive Pullies, 4.10s, Pro5.0 Shifter.
Coming before Summer: BBK LTs, BBK ORH, JLT CAI, 85mm MAF, 75mm TB, Trickflow Intake Manifold, King Cobra clutch kit.
Forged and girdled 306 shortblock w/ X303 Cam sitting in the garage awaiting some Twisted Wedge Heads next summer. |
04-06-2008, 02:28 PM
#20 | | 10 Second Club
| Quote:
Originally Posted by slow94GT buy yourself some suspension and some 4.10s, and you should be able to hit 9s. | Don't you think 4.10's is a bit much? Considering I'm spraying a 200 and running on 26's. IMO with some 4.10's I'm going to run out of gear before the 1/4 mile.
Posting Rules
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | | | |
