new combo... 9's? 69 camaro, 406 ci sbc, 650 crank hp (about), 3000 lbs raceweight, 4800 converter, powerglide (1.82 First gear), light weight driveshaft, Fab 9" rear
(4.56 gear), 29' tall slick. Fullllll racing suspension. Leaving off the footbreak. What do you all think... is 9's possible?
__________________ 99 T/A Under the knife -
85 MM mas,Ram Air,Lid,Ported Fast 92/92,Fast Rails
12 bolt 3.73's,TSP 233/239,Hooker 1.75 LT's,ORY,LM1 !Egr,!Air,160 Thermo,Yank PT4000,SVO 38LB injectors. Flt Stage 5, 4' Alum DS. BMR Trakpak, LCA's,Relo brakets,Dragbar,Panhard,Subframe's, Custom loop. QA1's in all 4. 300# fronts. ARP everything,Rings,Bearings,Lifters,11:1 compression.
Old setup -11.539@ 118.82 1.649 60' 1969 z28 - 12 point cage, Fab 9 rear, 406ci 650hp, Pwrglide 9.957 @ 133.92, 1.425 60' |
