Click here to visit LS1Tech
Click here to visit Performance Trucks
Click here to visit Mod Motor Tech
Click here to visit Modern Hemi
LS1Tech Wiki
LS1TECH
Go Back   LS1TECH > SBC-BBC-LT1-LT4 PERFORMANCE > Small Block & Big Block Chevy Specific
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into LS1Tech.com, click logo to login
Old 03-09-2009, 10:28 AM   #1
xx_ED_xx's Avatar
Trader Rating: 1
Default My Budget BBC 4th Gen Project
Well I got this car.
And since I have acquired it. I have added the koni double adjustable struts. Ls1 front brakes. Ls1 steering rack. C6 Corvette wheels. 275 40 18 front 285 30 18 20 rear. Soon the 3.23 posi will be replaced with a 3.42 posi (which I know wont last long). I also got a 1995 T/A 6 speed for the car. And a 2004 vortec 8100 4 bolt main.
The Engine.
Camshaft specs Numbers are Camshaft Lift (in): .527 intake / .544 exhaust Camshaft Duration (@.050 in): 224° intake / 234° exhaust
This intake or something similar
Yup thats a c5 vette with a vortec 8.1
And yes coil per cylinder.
And 14" c6 Z06 vette cross drilled rotors and 6 piston calipers.
And a paint job
I also am modifying an LT1 accessory bracket so I can keep power steering and air conditioning. I will take pictures of that as well.
xx_ED_xx is offline   Reply With Quote
Old 03-09-2009, 11:02 AM   #2
In-Zane Moderator
ZONES89RS's Avatar
Trader Rating: 4
Thats cool man, why arent you using a older block?
__________________
BUILT NOT BOUGHT
www.fquick.com/zones89rs
Quote:
Originally Posted by JUICED96Z View Post
The weight argument it stupid, compare a Warhawk LS motor to a all aluminum BBC, the weight difference is worth it to me with the kazillion more cubes.
ZONES89RS is offline   Reply With Quote
Old 03-09-2009, 11:04 AM   #3
xx_ED_xx's Avatar
Trader Rating: 1
Because I have this one and I need the crank sensor for my efi swap.
Old 03-09-2009, 01:30 PM   #4
camaroboricua's Avatar
Trader Rating: 0
This should turn out really nice, keep us updated please....
__________________
1996 Trans Am, Chrome C5 wheels, 350 gen 1 sbc,World Sportsman II heads, Summit 1.5 RR's, Lunati Cam, Edelbrock intake, Holley Carb, Walbro 255 lphFuel Pump, T5, Spec stage 2, Mac mids & Y pipe...
http://www.youtube.com/watch?v=LuFX9dgRAAo
camaroboricua is offline   Reply With Quote
Old 03-09-2009, 03:52 PM   #5
Trader Rating: 0
sounds like a cool project. keep us posted!
fastfreddy4ya is offline   Reply With Quote
Old 03-09-2009, 05:08 PM   #6
xx_ED_xx's Avatar
Trader Rating: 1
Thanks
Old 03-10-2009, 10:26 AM   #7
Trader Rating: 5
Should turn out really nice, but Budget and BBC don't belong in the same sentence
ulakovic22 is offline   Reply With Quote
Old 03-10-2009, 10:31 AM   #8
xx_ED_xx's Avatar
Trader Rating: 1
Sure they do. I paid nothing for the car. I paid 350 for the wheels and 100 for the tires. I paid 400 for the 6 speed with the flywheel I need for my 8100. 75 dollars for the cam. 300 for the intake with fuel rails and throttlebody. 600 for the complete long block
Old 03-12-2009, 12:33 AM   #9
xx_ED_xx's Avatar
Trader Rating: 1
Lil bit of progress today
Old 03-12-2009, 04:05 AM   #10
Trader Rating: 0
Is that the LT1 accessory bracket with all its accessories on a BBC? I had no idea you could throw them on there. Did you have to make any modifications for it to fit?
Edit: Just saw that you said that it was the LT1 bracket. More info please.
4K+Converter is offline   Reply With Quote
Old 03-12-2009, 08:27 AM   #11
capn smokey's Avatar
Trader Rating: 1
$400 for a T-56? Do you really think its gonna hold? I broke on at 450hp, your gonna shred that thing unless its built.
capn smokey is offline   Reply With Quote
Old 03-12-2009, 12:55 PM   #12
In-Zane Moderator
ZONES89RS's Avatar
Trader Rating: 4
Well Jeremy, it depends on hw he drives it and what he uses. A stock clutch will help it live, not to mention Radials and the aggressiveness it is driven.
__________________
BUILT NOT BOUGHT
Old 03-12-2009, 01:27 PM   #13
KCS
KCS's Avatar
Trader Rating: 11
F'n awesome. Keep us updated PLEASE!!!
__________________
KCS is offline   Reply With Quote
Old 03-12-2009, 02:55 PM   #14
OWN3D BY MY PROF!
Beaflag VonRathburg's Avatar
Trader Rating: 82
That's a really nice budget project. I haven't ever seen someone use the LT1 bracket on a big block.
Beaflag VonRathburg is offline   Reply With Quote
Old 03-12-2009, 07:39 PM   #15
xx_ED_xx's Avatar
Trader Rating: 1
Well no idea on the trani. It came out of a car that made a launch at pinks all out. It was in a 90 camaro behind a 383. The car went WAAAAAA and then boom and he coasted to the finish line. Its got a center force clutch and flywheel and a hurst shifter. So we will see. I have seen stock viper ones handle over a thousand at the wheels. But this is just a lowly 95 trans am trani so... (crosses fingers)
Old 03-12-2009, 07:43 PM   #16
xx_ED_xx's Avatar
Trader Rating: 1
I was hoping to push the car in tonite an trial fit my setup on the test motor. But the Found On Road Dead I am borrowing decided to eat an ignition module.
Old 03-12-2009, 11:25 PM   #17
Trader Rating: 1
Quote:
Viper trannys are completely different than f-body transmissions. I would say you might make one or two good passes before it snaps under that bbcs torque. I would highly recommend spending about 1000 and getting it built because you never know what else might break when it goes.
Old 03-15-2009, 04:27 PM   #18
xx_ED_xx's Avatar
Trader Rating: 1
aye aye capn
Old 03-15-2009, 05:06 PM   #19
In-Zane Moderator
ZONES89RS's Avatar
Trader Rating: 4
Depends on weight of the car, clutch and tires. The T56 can take a beating as long as the owner has never ground the gears and maintained it.
__________________
BUILT NOT BOUGHT
Old 03-15-2009, 05:08 PM   #20
xx_ED_xx's Avatar
Trader Rating: 1
Agreed
Tags
4th, bbc, gen
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
LS1TECH - Archive - Top
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
Advertising - Terms of Service - Privacy Policy - JOBS
