The weight argument it stupid, compare a Warhawk LS motor to a all aluminum BBC, the weight difference is worth it to me with the kazillion more cubes.
Looks good,hopefully you can get enough air into the radiator to keep cool? I've got a question for ya please, what brake master is that? I have a hydro-boost conversion I put on mine from an astro van and used a G30 van master and my brakes stop fine, just has a very hard pedal "almost 0" travel, and I think it is in the master because my proportional valve is basically useless for my rear disc, seems to make no difference when adjusted.
Thanks,
Thanks,
Using the astro van master. I haven't had much time to play with it. I actually gotta take it back off to find out why its leaking
Super Baddass Dude! The headers look cool as hell!...Make me a set...looks like they'll fit a camaro just fine!!!
Thanks, Those things were such a pain in the butt. Plus I just tacked everything together and had someone tig them together. Took a lot of time to make those things how I wanted to. I probably would just flip some manifolds around if I did it all over again
I was pretty sure from your picture it was an Astro van hydroboost, but the polished aluminum master cylinder is what I was curious came from?? Looks like an aftermarket one?
Reason: sp
