Click here to visit LS1Tech
Click here to visit Performance Trucks
Click here to visit Mod Motor Tech
Click here to visit Modern Hemi
LS1Tech Wiki
LS1TECH
Go Back   LS1TECH > SBC-BBC-LT1-LT4 PERFORMANCE > Small Block & Big Block Chevy Specific
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into LS1Tech.com, click logo to login
Old 06-21-2009, 08:29 PM   #1
BassProCamaro97's Avatar
Trader Rating: 6
Exclamation Engine install from the top?
Have any of you installed a small block or big block from the top with the suspension in place?
I tried to mock up my motor today from the top and I was having a hell of a time and ended up calling it a day with out getting it set.
Any tips or suggestions are much appreciated.
Thanks,
~Jim~
__________________
97 Camaro Z28 M6
My Camaro build:
http://www.ls1tech.com/forums/small-...27-camaro.html
BassProCamaro97 is offline   Reply With Quote
Old 06-22-2009, 02:28 AM   #2
In-Zane Moderator
ZONES89RS's Avatar
Trader Rating: 4
Yep, mine went in and out from the top on my 95 with no problem.
__________________
BUILT NOT BOUGHT
www.fquick.com/zones89rs
Quote:
Originally Posted by JUICED96Z View Post
The weight argument it stupid, compare a Warhawk LS motor to a all aluminum BBC, the weight difference is worth it to me with the kazillion more cubes.
ZONES89RS is offline   Reply With Quote
Old 06-22-2009, 07:27 AM   #3
xx_ED_xx's Avatar
Trader Rating: 1
I pulled the 496 out of mine with trans from the top.
__________________
xx_ED_xx is offline   Reply With Quote
Old 06-22-2009, 07:39 AM   #4
Trader Rating: 6
Am I missing something?
I did not have the trans on the engine so I'm sure that played in to it but I could not get the engine far back enough to meet up with the motor mounts.
Is it really just that simple or are there some tricks to it?
Thanks for the replies.
~Jim~
__________________
97 Camaro Z28 M6
My Camaro build:
Old 07-01-2009, 10:46 PM   #5
DarkJuggalo's Avatar
Trader Rating: 3
Send a message via AIM to DarkJuggalo
well all the times i do mine, i do trans and motor together like so:
usually if it wont seat correctly, you may wanna make sure the trans is lining up correctly. or try lowering it a bit more and pushing it back. you just gotta play with it.
__________________
DarkJuggalo is offline   Reply With Quote
Old 07-09-2009, 07:16 PM   #6
Trader Rating: 0
We used an adjustable engine hoist carrier. it lets you shift the angle of the engine.
like this one
http://www.agrisupply.com/product.asp?pn=57606
monkihead is offline   Reply With Quote
Old 07-10-2009, 07:31 AM   #7
Trader Rating: 6
Ya I thought about using a leveler as well.
I'm getting the car back today so I'll have to look into getting a leveler.
Thanks,
~Jim~
__________________
97 Camaro Z28 M6
My Camaro build:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
LS1TECH - Archive - Top
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
Advertising - Terms of Service - Privacy Policy - JOBS
