Click here to visit LS1Tech
Click here to visit Performance Trucks
Click here to visit Mod Motor Tech
Click here to visit Modern Hemi
LS1Tech Wiki
LS1TECH
Go Back   LS1TECH > SBC-BBC-LT1-LT4 PERFORMANCE > Small Block & Big Block Chevy Specific
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into LS1Tech.com, click logo to login
Old 06-22-2009, 05:20 PM   #1
Trader Rating: 0
Default 1997 vortec 350 power?
im shooping around for a motor for my iroc project..and i found this 97 vortec 350 out of a 2x4 suburban..i tried to serch it but its not working..can someone please tell me what kind of power these things made stock?
__________________
1986 Mustang GT 5.0 5spd 60,XXX Original
1989 Pontiac Formula 5.0 TPI-3.73s Restored by Me
5.0&5.0 is offline   Reply With Quote
Old 06-22-2009, 05:34 PM   #2
BeefTip's Avatar
Trader Rating: 0
Location: Somewhere between Auburn, AL and Columbus, GA
255 or close too it at the crank, real good torque
__________________
BeefTip is offline   Reply With Quote
Old 06-22-2009, 05:53 PM   #3
Trader Rating: 0
niccee.....did the 5.0 vortecs come with 97 suburban 2x4?
does anyone have the casting numbers for the block..so i can make sure its a 350 motor
thx bill
Old 06-22-2009, 08:31 PM   #4
Trader Rating: 0
nevermind on that last post lol...but were exactly is the block castings on these..on the back?
Old 06-23-2009, 12:09 AM   #5
1991 Chevrolet Camaro
My Garage
Trader Rating: 0
the block numbers are the same as they always been. you can look on the side or on the back. they will actually say 5.0 or 5.7 on them. but the 350 is the one with a 080 for the last three. thats the most common. or look for an R at the 8th digit in the vin if its in the truck still.
__________________
7.0 camaro is offline   Reply With Quote
Old 06-23-2009, 08:33 AM   #6
BeefTip's Avatar
Trader Rating: 0
I would go ahead and replace the intake gasket if you use a vortec motor....if you are switching to carb then you would have to do that anyway.
__________________
Old 06-23-2009, 10:50 AM   #7
mred's Avatar
Trader Rating: 0
the 350 blocks casting is 880. i built a 350 with a lt4 hot cam and a 2500 stall that bitch would run.
mred is offline   Reply With Quote
Old 06-23-2009, 11:41 AM   #8
My Garage
Trader Rating: 0
hell your right. i dont know what i was thinking. its hard to remember all these numbers. 880 is right though.
__________________
Old 06-23-2009, 03:14 PM   #9
Trader Rating: 0
Quote:
yea if i get this motor..im to go with a TPI set up with an edelbrock intake 24lb injectors..already have edel shortys/y pipe and 3.73 posi in it...the following mods would be a 2500 stall and edel TPI runners
this thing should be a torque monster with a tpi right guys?
thx for your help guys
Old 06-23-2009, 04:21 PM   #10
My Garage
Trader Rating: 0
not a big fan of the tpi. but it should feel better than a 305
__________________
Old 06-23-2009, 04:29 PM   #11
BeefTip's Avatar
Trader Rating: 0
why not just a good holley 750 and swap the intake out to a vortec-carb intake...like a rpm air gap or something.
__________________
Old 06-23-2009, 05:10 PM   #12
My Garage
Trader Rating: 0
the tpi is ok. but im not too sure on that "conversion" intake. its only rated to 5500. i would at least want 2500 to 6-6300.
__________________
Old 06-23-2009, 05:38 PM   #13
Trader Rating: 0
ehh i kinda like the tpi(its not TOO bad)...but with 305 i can never spin the tires from a roll or anything even with 3.73s(it will chirp somtimes tho)...its actually boring to drive bc of that...i jus wanna go from a slow roll like 5mph mash the gas and spin those fukkers..its anoying...im hoping a 350 vortec tpi with a 2500 stall will be able to do that
Old 06-23-2009, 06:24 PM   #14
Trader Rating: 1
Send a message via AIM to Bowtie_Aaron Send a message via MSN to Bowtie_Aaron
yeah 880 casting number is on the both sides of the block between the freez out plugs, and on the driver side rear of the block on the pad that the trans attaches to.
they are 1pc rear seal, roller cam motors.
you will need a special vortec tpi lower intake. i think edelbrock makes them. they are like 450 bucks though.
you can pick up air gap intakes real cheap for around 50-100 used.
factory rated at 260hp, 325-350tq or something like that. stock they run real strong.
i have a vortec block in my chevelle. has a voodo roller cam in it. you can use lt1 cams just have to push the down pin in.
if you plan to cam the motor, you must cut the spring pockets and retainer guides as the factory config is only good to .450ish lift.
good luck.
aaron
__________________
71 velle 355, 231/239 voodoo roller, Brodix IK180,750 holley, m20 muncie, 355 posi
94 T/A GT, A4, bypassed TB, Corsa Cat back, 3.23..new DD
Bowtie_Aaron is offline   Reply With Quote
Old 06-25-2009, 08:49 AM   #15
mred's Avatar
Trader Rating: 0
Quote:
he would be "SO" much "HAPPIER"
Old 06-25-2009, 09:21 AM   #16
1redta's Avatar
Trader Rating: 0
stealth ram FTW
__________________
96 Trans Am M6 w/street twin,fake ws.6 : hood from harwood, late model 17" aluminum wheels and sway bars, pcms 4 less computer, LE2 heads, ported intake, Bauer custom cam, RPM built! stock cube bottom end, Canton road race oil pan, FLP headers w/ crapmaster exhaust, 10bolt w,3.73's and Auburn pro diff
"give a firefighter a rubber hammer and he could break an anvil"
1redta is offline   Reply With Quote
Old 06-25-2009, 11:38 AM   #17
BeefTip's Avatar
Trader Rating: 0
__________________
Old 06-28-2009, 09:10 AM   #18
mred's Avatar
Trader Rating: 0
you dont remember what say in your post do you?
Old 06-30-2009, 12:23 AM   #19
BeefTip's Avatar
Trader Rating: 0
yeah i do, i just have no idea what your quotations meant retard
__________________
Old 07-02-2009, 11:45 PM   #20
mred's Avatar
Trader Rating: 0
Happiness is a state of mind or feeling such as contentment, satisfaction, pleasure, or joy. A variety of philosophical, religious, psychological and biological approaches have been taken to defining happiness and identifying its sources.
DUMBASS
Tags
1997, 350, 880, cam, casting, chevy, computer, hot, intake, lt4, motor, performance, sale, tpi, vortec
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
LS1TECH - Archive - Top
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
Advertising - Terms of Service - Privacy Policy - JOBS
