Got bored so i thought I'd post up a few pics of my SBC 94 camaro. 377, 13:1, Dart Iron Eagles, super victor, solid roller, single cheater plate, runs 6.0's on 180 shot. True 10.5's and stock suspension. Looking for 2" Headers for it now, currently have 1-3/4" dynatechs. Where can i find 2" primaries? Might just have to build some....
The weight argument it stupid, compare a Warhawk LS motor to a all aluminum BBC, the weight difference is worth it to me with the kazillion more cubes.
Thanks for the kind words. Going to make a few improvements over the winter and up the shot. Hopefully run some 5.70's or a .60 if I really get it working good.
The motor plates are great for giving me extra room under the car to work, especially changing spark plugs. The dynatech headers SUCK for changing plugs with these angle plug heads so I do it from under the car.
Sometimes they are a little bit of a pain in the ass to get everything lined up. Bottom line, if its an all out race car, go for it. Street strip deal, I wouldn't mess with it.
The color is custom color we made up. Its close to the HOK tangelo pearl, but with LOTS of gold pearl in it. Under the sun or lights it really pops, when its cloudy it can look kinda dull, but overall I like it.
very nice car and the color is awesome. Just curious, What alternator bracket is that?
It's from Jones Racing Products. http://www.jonesracingproducts.com/ I used their brackets and alternator and made my own spacers. The motor plate was also notched for clearance. I did end up having to bolt the lower bracket to the motor plate to keep everything rigid. The kit was originally designed to use a cog style belt with a drive mandrel on the crank, but I switched to the less expensive V-belt design.
Thank you. I will give them a call tomorrow.
__________________ 2000 SS M6 black SLP package, spec stage 2 clutch, RAM billet steel flywheel, BMR sub frames, Lakewood LCA, Random Tech. Adj torque arm,
Cool. I bought my stuff second hand, but I'm sure you can order just the brackets from them. You'll need the upper C shaped bracket and a lower curved bracket. Let me know if you'd like more pics of the setup.
Maybe... I'm using a factory 400 block, I'm not sure if it can handle that or not.
o well on that note i wouldnt even have nitrous near that motor lol. i have a 406 thats a stock 511 block. (yes its a two bolt main) im just bracket racing the motor. to scared to spray it. i know my luck soon as i hit the go fast button it would scatter.
This block started as a 2 bolt main, but I've got splayed 4 bolt caps in it. Scat crank and H beam rods, and JE off the shelf n20 pistons. Plan to pull it apart and see how it looks this winter. I've got about 20 nitrous passes on it now.
Are those headers for and SBC or an LT1. If you come across a place making 2" primary headers for a SBC please let me know, Im having trouble finding any kind of headers for SBC in a f-body. Im in the middle of a SBC swap into my f-body and would really like to find some 2" primary headers.
__________________
Wes Buck
Editor/Publisher
Drag Illustrated Magazine
1998 Pontiac Trans Am - Sport Metallic Gold - LS1/M6
Hey Wes, this is Christian from up in Iowa. Hows it goin!?
They are Dynatech LT1 headers. Headman has a set of their Hustler Headers with 1-7/8" primaries and spread port flanges. Thats the closest I've found for off the shelf stuff. Looks like its going to be custom for 2".
__________________ 1994 Camaro 377ci sbc. Single plate, stock suspension, 28x10.5's. 6.0's at 114 on ~180 shot
