BBC short block/TH400/misc. stuff- Have some stuff left over from the swap that needs a new home....
Can/will part out items separately... all items can be seen at Vengeance Racing-
BBC 454" short deck short block...
10.5:1 pump gas motor...
Minimal miles(less than 4000)...
Cross hatching on cyl. walls still there and looks good...
Miloden Gear drive/cover...
Mallory front drive distributor...
Roller lifters(brand unknown)....
Roller cam(specs unknown-guessing 260*/680" range.... choppy idle).
I beam rods(brand unknown)...
Forged flat tops/valve reliefs(brand unknown)/piston tops look almost new...
Forged crank(brand unknown)...
ARP head studs...
ARP 12 point rod bolts...
FluidDamper two piece balancer...
Flex plate...
Will include coated 2 1/4" long tube headers if needed...
Will include front motor plate if needed...
Compression check/leak down numbers look good per Lamar Walden Automotive before motor was pulled. No taps, knocks, noise, smoke or oil use, and ran strong before pulled.
This would be a great street car/truck motor..... install and drive-
Need to see $800.00 OBO complete -
BBC PowerMaster starter.
Nearly brand new... 4-5 starts on unit.
Good to 14:1 CR...
Clockable mount...
Paid $300.00+
$200.00 -
BBC two wire alternator w/billet mount...
$150.00 -
TH400 trans.
Manual forward pattern valve body...
Hurst Quarter stick shifter(forward pattern)...
3500 converter...(brand unknown)
TCI SFI bell housing shield...
TCI SFI trans blanket....(brand new never installed)...
NO slip/NO drip..... perfect operating condition...
Need to see $600.00 OBO complete -
LT1('93-'97) hood...
Excellent condition...
$100.00 -
__________________ User title null and VOID
'93 mullet mobile -aka Purple Hope....... |
