Click here to visit LS1Tech
Click here to visit Performance Trucks
Click here to visit Mod Motor Tech
Click here to visit Modern Hemi
LS1Tech Wiki
LS1TECH
Go Back   LS1TECH > CHASSIS, SUSPENSION, APPEARANCE > Stereo & Electronics
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into LS1Tech.com, click logo to login
Old 10-23-2009, 09:27 PM   #1
Jeff Smith's Avatar
Trader Rating: 20
Default where wires of headlights/fogs connectors goes to ?
The previous owner had wrecked on front end. I am going to installed an aftermarket HID or OEM headlights. I don't know which wires goes to turn signals, the headlights, and the fog lamps, Could anyone please tell me which wire goes where? This vehicle is '01 Camaro Z28.
Had Update on Nov.4th.
Headlights/Fog Lamps @right (pass.) side
Connector#1: High Beam Headlight (Lime wire:"+")
Connector#2: :Low Beam Headlight (Tan wire: "+")
@Right Side
Connector#3:Turn (right) signal ("+")
Connector#4:Lamp ON when switch on>side marker ("+") goes with #7
Connector#5:Lamp ON when switch on>side marker ("+") goes with #6
Connector#6:Lamp ON when switch on>side marker ("-") goes with #5
Connector#7:Lamp ON when switch on>side marker ("-") goes with #4
Connector#8: Fog Lamp ("-")
Connector#9: Fog lamp ("+")
Headlights/Fog Lamps @Left (driver) side
Connector#1:Low Beam Headlight (Tan wire ("+")
Connector#2:High Beam Headlight (Lime wire ("+"))
@ Left Side
Connector#3: Fog Lamp
Connector#4: :No responsive when headlight switch turn on
Connector#5::Lamp ON when switch on>side marker
I use this headlight for testing, looks foggy badly.
__________________
F/S: Found-Barn
F/S: LQ4 Motor/Block
2001 Camaro LS2 Carbed {56 Tremec 6spd.} {AFCO radiator} {Kooks}
2001 Chevy Camaro
Jeff Smith is offline   Reply With Quote
Old 10-30-2009, 09:06 AM   #2
Jeff Smith's Avatar
Trader Rating: 20
??? 32 Visited. No help
__________________
F/S: Found-Barn
2001 Chevy Camaro
Old 10-31-2009, 02:52 AM   #3
Copy & Paste Moderator
VIP1's Avatar
Trader Rating: 0
#1 & #2 are the low beam and high beam headlight sockets, but I forget which is which. You can find out real quick by testing them. Hook up some bulbs, turn on the headlights. See which ones are on. Flip the high beam switch see which change. Then you'll know which is which.
#6 in the second to last pic is a fog light bulb, but it looks like just the connectors and not an actual socket. You can confirm that by turning on the fog lights and see if that lights up.
#5 in the second to last pic looks like either the turn signal or side marker. I'm not sure which, but activating the turn signals will tell you that.
__________________
- 2001 Black Formula --- 75th Anniversary Package --- www.fadingarrow.com -
Performance Mods: Bilstein HD, Lid & Holly Powershot, Brembo Blanks & Hawk HPS Pads, ATE Super Blue Brake Fluid
Appearance Mods: Black Z06 Motorsports (17x9.5), F1 GS-D3 (275/40/17), Silver Door Panel & Arm Rest Fabric, Silver Vent Rings, A4 Leather Shift Boot, Hella H9 Projector Headlights, Pioneer AVIC-D3
--- Lighting FAQ -- Sig Rules -- General Suspension Issues/Questions FAQ ---
VIP1 is offline   Reply With Quote
Old 11-04-2009, 08:32 PM   #4
Jeff Smith's Avatar
Trader Rating: 20
Thanks VIP for helping.
Had tested with Multimeter to those wires ID and fixed it ..
I can't solve with the light blue wire #4 at left side..
__________________
F/S: Found-Barn
2001 Chevy Camaro
Old 11-06-2009, 01:33 AM   #5
Jeff Smith's Avatar
Trader Rating: 20
I need help, where is the #4 (color:light blue) red mark wire @ left front side go to? I believe so, that wire was turn signal, had burned it so I need to know where it wire go to. I can replace new wire. Beside driver's door side at fuse box?
Pix>>#4
__________________
F/S: Found-Barn
2001 Chevy Camaro
Old 11-06-2009, 11:49 AM   #6
Ungrounded Director
WhiteBird00's Avatar
Trader Rating: 4
Light blue wire on left side should be turn signal/DRL power. The equivalent wire on the right side will be dark blue. Easy test: use a test light to check for power - wire should have no power until the ignition is on and the parking brake is released (DRL) and should have flashing power with the left turn signal on.
__________________
White 2000 Trans Am
usual bolt-ons and some appearance/convenience mods
WhiteBird00 is offline   Reply With Quote
Tags
01, camaro, change, fog, headlights, light, wires
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
LS1TECH - Archive - Top
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
Advertising - Terms of Service - Privacy Policy - JOBS
