Click here to visit LS1Tech
Click here to visit Performance Trucks
Click here to visit Mod Motor Tech
Click here to visit Modern Hemi
LS1Tech Wiki
LS1TECH
Go Back   LS1TECH > CHASSIS, SUSPENSION, APPEARANCE > Stereo & Electronics
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into LS1Tech.com, click logo to login
Old 11-02-2009, 12:27 PM   #1
ROLL TIDE ROLL!
josh99ta's Avatar
Trader Rating: 0
Default Why aren't my plug-and-play HIDs working (DDM)?
Got the DDM tuning plug-and-play 35w HID kit for 9006 bulbs for the SS. I've installed a few HID kits before (GTO, Integra) and both went in easily and worked flawlessly. This kit seems to have the best overall quality, yet I'm getting no light. This kit seems to have a few less wires than the other kits I've installed though.
For this kit I have the stock headlight harness going into the clip near the ballast that it fits into. Then I have the wiring (two wires) coming out of the ballasts and igniters into the respective clips on each HID bulb.
There is an extra two-wire clip that looks to only serve as an extension between the factory headlight harness and the input plug of the ballast, and where I mounted my ballasts I didn't need it so it's not in use (although I did try plugging the stock headlight harness into it, and the other end of it into the input of the ballast when the HIDs didn't work initially and they still didn't work, so I unplugged it and hooked it up the original way to reduce wiring).
Unless I'm just having an off-day and really missing something glaringly obvious this should work, but it isn't. On the Integra I did HIDs on I had to ditch the factory high beams all together and use the high beam plug to actually get enough juice to power the ballast. The kit was like that by design. I really don't think that's the case with this 9006 kit because I haven't heard of anyone else on the board here losing high beams to make a HID kit work. I'm just finding it odd that it isn't working, and doubt I'd have either two defective ballasts, bulbs, or both.
__________________
Joshua Gull | http://www.fquick.com/josh99ta
Onyx Black 2000 Chevrolet Camaro SS LS1 M6 Daily Driver
josh99ta is offline   Reply With Quote
Old 11-02-2009, 03:36 PM   #2
2002 Pontiac Firebird
pheer's Avatar
Trader Rating: 3
i've always tied them to the battery directly, and had them turn on with a relay from the stock harness
__________________
What's the quickest way to 500rwhp NA?
2002 BSM Firebird Trans Am A4 - 1 of 344 -Lid, Smooth Bellows, Ported TB, LCAs w/Relo. Brackets, PHB, Upper PHB Relo., !GF, more on the way...
pheer is offline   Reply With Quote
Old 11-02-2009, 04:11 PM   #3
ROLL TIDE ROLL!
josh99ta's Avatar
Trader Rating: 0
Who designs these kits?
I did some more online searching and found a troubleshooting guide. Where the stock harness plugs into the ballast I had it attached so that the clip fit over the little spike to hold it all together (read: the correctly installed way). I unplugged that, flipped the plug around so that the clip didn't fit over the little spike, so that it was plugged in upside down. The lights fired right up. Way to go DDM, hopefully the guts of the ballast are better in design than the plugs that hook it all up.
__________________
Old 11-02-2009, 06:18 PM   #4
bmnicolosi's Avatar
Trader Rating: 1
I've put in quite a few hid's in chevy's that required the plug to be flipped. Dont think its just DDM
__________________
99 M6 t-top leather silver/pewter Z-28, 408, L92 heads, big a$$ cam, 459hp, 448tq
05 bermuda blue/green metallic Avalanche, sunroof, leather, BOSE, 24-inch rims
bmnicolosi is offline   Reply With Quote
Old 11-02-2009, 09:36 PM   #5
ROLL TIDE ROLL!
josh99ta's Avatar
Trader Rating: 0
Guess it's just Chevy's wiring? Because obviously nothing is exact vehicle specific, it's just a 9006 HID bulb kit. Way to go then GM!
Otherwise the kit is tip top. It's the smallest ballast I've ever seen, and it's so damn solid. Best kit to date I've installed. The plug thing just irked me.
__________________
Old 11-02-2009, 10:04 PM   #6
Copy & Paste Moderator
VIP1's Avatar
Trader Rating: 0
The problem is with the Camaro's wiring. Its reversed. You have to flip it for most HID kits.
__________________
- 2001 Black Formula --- 75th Anniversary Package --- www.fadingarrow.com -
Performance Mods: Bilstein HD, Lid & Holly Powershot, Brembo Blanks & Hawk HPS Pads, ATE Super Blue Brake Fluid
Appearance Mods: Black Z06 Motorsports (17x9.5), F1 GS-D3 (275/40/17), Silver Door Panel & Arm Rest Fabric, Silver Vent Rings, A4 Leather Shift Boot, Hella H9 Projector Headlights, Pioneer AVIC-D3
--- Lighting FAQ -- Sig Rules -- General Suspension Issues/Questions FAQ ---
VIP1 is offline   Reply With Quote
Old 11-02-2009, 11:24 PM   #7
ROLL TIDE ROLL!
josh99ta's Avatar
Trader Rating: 0
It's amazing that through a number of searches I never saw anything about this anywhere. Hopefully this post will serve as helpful to someone down the road.
HIDs are in the fogs and low beams. Looks great. Definitely not the cutoff I had in the GTO with the projectors, but it's really not that bad. Took it for a spin tonight and had one person flash me (I've had people do that to me in the GTO too, people do that to me with halogens in the truck, etc), but passed plenty of people who just rolled right on by. The driver's side light is a little higher than the passenger's side but I'll fine tune it when the Halo lights come in in a few days.
__________________
Old 11-03-2009, 04:55 AM   #8
R.I.P. Bret Powell
Viscious's Avatar
Trader Rating: 0
You'll get flashed occasionally with non projector housings.
Projector's = win.
What sort of bulb temperature did you go with on the fogs and lows? Any pictures?
DDM is definitely a cheap kit, but if you do a proper burn in time and try not to blink them they should last a while.
__________________
Viscious is offline   Reply With Quote
Old 11-03-2009, 08:18 AM   #9
ROLL TIDE ROLL!
josh99ta's Avatar
Trader Rating: 0
The funny thing is I got flashed just as much WITH projector housings when I had the GTO, and got flashed with regular old halogens in the 2008 F150 I had too, so it's hard to contribute one person flashing you every once in a blue moon to having blinding headlights, simply because people around here are flash-happy. I've seen stock BMWs, Audis, and Cadillacs flashed a lot too. By my eye there isn't a sharp cutoff, but the lights definitely aren't blinding either.
I've had a few people recommend the DDM kit over other kits out there, and it looks identical to the kit I've seen a few people go with from some big name companies, although who can ever really be sure these days.
I went 6000k in the lows and fogs. Normally I like to stay in the 4300-5000k range, but for the non-projector housings taking a little edge off the white with the 35w 6000k bulbs was the best bet I thought.
__________________
Old 11-20-2009, 04:32 PM   #10
MattxFatal's Avatar
Trader Rating: 3
Glad you posted this.
I'm about to place my order for this exact kit and was wondering about any set backs.
Seems like the fault really does fall on our car's wiring.
-Matt
__________________
02 A4 SSM Z28.
A couple things...
MattxFatal is offline   Reply With Quote
Tags
9006, ddm, hid, tuning
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
LS1TECH - Archive - Top
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
Advertising - Terms of Service - Privacy Policy - JOBS
