Click here to visit LS1Tech
Click here to visit Performance Trucks
Click here to visit Mod Motor Tech
Click here to visit Modern Hemi
LS1Tech Wiki
LS1TECH
Go Back   LS1TECH > CHASSIS, SUSPENSION, APPEARANCE > Stereo & Electronics
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into LS1Tech.com, click logo to login
Old 11-04-2009, 03:15 PM   #1
TAtoad's Avatar
Trader Rating: 1
Default Will it work for long? 10inch on stock amp
I got a DS stealth box with a 10 inch kicker comp. Im saving up for the amp and the rest of the installation stuff. earlier i tried running it with power supply from the Sail panel midbass drivers, and it works well, kicks pretty good, not great though. Is there any chance i am harming the monsoon syster, or the sub itself?? i'm going to do it right eventually, but in the meantime is this ok to do?
__________________
2002 ws6 m6
LM2 with cutout. SLP lid/smoothbellow/K&N. WS6 store Short stick.!CAGS!
Tick Performance Clutch Master Cylinder
TAtoad is offline   Reply With Quote
Old 11-04-2009, 03:23 PM   #2
LS1TECH Sponsor
KEE AUDIO's Avatar
Trader Rating: 58
Depends on how hard you try and run it and how it is hooked up. If you try and push it too much you can potentially clip the amp and do damage to both the sub and the amp. Generally it's one or the other and not both though.
How so you have it hooked up right now? It's important because if you have the wrong ohm load on the amp you can damage it.
__________________
KeeAudio.com
KEE AUDIO is offline   Reply With Quote
Old 11-04-2009, 06:41 PM   #3
TAtoad's Avatar
Trader Rating: 1
i disconnected the blown midbass driver, spliced the connector and ran the same guage wire to the sub in the rear
__________________
2002 ws6 m6
Old 11-05-2009, 02:40 PM   #4
LS1TECH Sponsor
KEE AUDIO's Avatar
Trader Rating: 58
From just one side or both sides? Did you use both pairs of wires on a DVC subwoofer? Need a little more to go on.
If you used just one side (both pairs of wires on tha side) and you are using a DVC sub on that side you are sending about 45-50watts (maybe) to that sub and it will be ok. Not going to be very loud or anything but it isn't overloading the amp.
__________________
KeeAudio.com
Old 11-06-2009, 01:59 PM   #5
TAtoad's Avatar
Trader Rating: 1
im running power from only the passenger side sail panel. would running power from both have an advantage??
__________________
2002 ws6 m6
Old 11-06-2009, 02:24 PM   #6
LS1TECH Sponsor
KEE AUDIO's Avatar
Trader Rating: 58
If you ran another sub then yes but the way it's set up you really couldn't do that unless you had a quad voice coil sub but that would then blow the amp due to lowering the impedance too much.
Leave it as is for now and it should be fine but I wouldn't push it real hard. Again, your only sending that sub about 45-50watts RMS and pushing it too hard would put too much on the amp.
__________________
KeeAudio.com
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
LS1TECH - Archive - Top
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
Advertising - Terms of Service - Privacy Policy - JOBS
