Click here to visit LS1Tech
Click here to visit Performance Trucks
Click here to visit Mod Motor Tech
Click here to visit Modern Hemi
LS1Tech Wiki
LS1TECH
Go Back   LS1TECH > CHASSIS, SUSPENSION, APPEARANCE > Stereo & Electronics
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into LS1Tech.com, click logo to login
Old 02-06-2002, 10:23 PM   #1
Trader Rating: 0
Default how to make ta fog lights stay on w/ hi beam?
isn't there some way to make my trans am's fog lights stay on when I turn the high beams on?
__________________
99 GMC Z71 x cab 5.3
mods so far> Mezeire wp,billet grille, gms maf,K&N fipk, cognito 12" lift, super swamper 38's, weld mountain crushers, kodiak sidewinder automatic steps, thunder tb, gms maf, K&N fipk, asm headers, true duals, LS1 fans, thunder 212/218 558/563 112lsa cam soon!
99 ws6 MTI 422, gone
<a href="http://www.geocities.com/raptorterry" target="_blank">www.geocities.com/raptorterry</a>
highgmc is offline   Reply With Quote
Old 02-06-2002, 10:26 PM   #2
BIGBOS's Avatar
Trader Rating: 0
Send a message via AIM to BIGBOS
Default Re: how to make ta fog lights stay on w/ hi beam?
I'm sure there is, the fog lights really don't serve much of a purpose anyways...they don't make any light difference when you have the regular lights on....try flipping them on and off at night....you will see no change... <img src="gr_stretch.gif" border="0">
Why are you trying to blind people anyways... <img src="gr_eek2.gif" border="0"> <img src="gr_images/icons/wink.gif" border="0">
__________________
-2008 Jetstream Blue Z06-
-2006 TrailBlazer SS LS2 395hp - (SOLD) -
-2003 Electron Blue 50th Anniv. Corvette - ZO6 - (SOLD) -
-2001 NBM T/A Firehawk #236 of 540 - 660rwhp - (SOLD) -
BIGBOS is offline   Reply With Quote
Old 02-07-2002, 01:00 AM   #3
Trader Rating: 0
BIGBOS,
Maybe yours are broken. Mine make a difference.
Try to trace wires. If a standard Auto relay is uses find the wire that connects to the high beams and ground it. Maybe!
__________________
2004 Silverado VHO
LQ9 6.0, 20's, 3.73's, torsion bar suspension, 2wd
Round Rock TA is offline   Reply With Quote
Old 02-07-2002, 07:50 AM   #4
Jax White TA's Avatar
Trader Rating: 0
Send a message via AIM to Jax White TA
Mine make a big difference too.
Jax White TA is offline   Reply With Quote
Old 02-07-2002, 11:18 PM   #5
Trader Rating: 0
This is one way we use to do it on the Grand Prix
The factory fog lights are wired to their own relay, except the ground wire is run through the high beam relay. When the brights come on the fogs are no longer grounded so they turn off.
Bend the ground plug on the relay up, connect a wire to it, then attach the other end of the wire to the car body somewhere.
[ February 07, 2002: Message edited by: Paul Bruno ]</p>
__________________
2k2 NBM WS6 A4 TCS
Paul Bruno is offline   Reply With Quote
Old 02-09-2002, 10:18 AM   #6
Trans Am WS6 RGS's Avatar
Trader Rating: 0
Send a message via AIM to Trans Am WS6 RGS
Cut the light green wire!! I did that "mod" long ago. I will double check to make sure that its the light green wire (In your fuse box) so that you dont accidently cut the wrong wire.
Just look under the fuse box and there should be a bunch of wires down there. Cut the light green one and the ground it while taping off the other end, just so it doesnt get wet when it rains or when you wash your car.
Honestly the fog light dont do much but neither do the ones on other cars, then again they really arent fog light more as they are driving lights. Though I can notice the little bit of light when I flip them on and off.
Having all your lights on looks cool and that was the only reason I did it. That and to attempt tp blind those who blind me.
<img src="graemlins/formula.gif" border="0" alt="[Pontiac]" />
__________________
2000 Black Trans Am WS6 M6 #4047
PP "LS6" Stg 2 heads, TSP 231/237 112 lsa cam, SLP LT Headers, Sweet-Thunder True Duals w/side exits, Predator tuner, TR6 spark plugs, BG Ram Air, Whisper Lid w/K & N, TT2's w315s in the rear, Embroidered Headrests.
2005 Silver Toyota Prius
Stock and staying that way!
Trans Am WS6 RGS is offline   Reply With Quote
Old 02-10-2002, 05:23 PM   #7
SS 414's Avatar
Trader Rating: 0
I have my fog lights stay on with my high beams. I pulled the fog light relay, and replaced it with a wire. Here's a pic...
You can see the black wire I have in there. It makes the fog lights stay on anytime the lights are on. Low's, high's, and parking. Also when you lock and open the doors with the remote, the fog lights flash also.
__________________
George
2000 Camaro SS
FastLSX
SS 414 is offline   Reply With Quote
Old 02-10-2002, 10:22 PM   #8
BIGBOS's Avatar
Trader Rating: 0
wheres the other end of that wire going to?
__________________
Old 02-11-2002, 12:07 AM   #9
SS 414's Avatar
Trader Rating: 0
[quote]Originally posted by BIGBOS:
<strong>wheres the other end of that wire going to?</strong><hr></blockquote>
Sorry, should have explained a little more. When you pull the fog relay out, you will see there are 4 pin holes, where the pins on the fog relay went in. They are numbered, I don't remember the specific numbers off the top of my head. The wire is going from one hole into the other one. If I remember correctly, the holes you have to connect with the wire are #'s 1 & 8. But like I said, I don't remember off the top of my head. If we are looking at the picture from this frame of reference, the wire is going from the bottom left hole and the top right hole (on a diagonal). I'll look tomorrow if you want me to. It's dark out right now and pouring.
__________________
George
2000 Camaro SS
FastLSX
Old 02-11-2002, 12:08 AM   #10
SS 414's Avatar
Trader Rating: 0
Oh yeah, one more thing. This is on a 2000 Camaro. I belive it would be the same for a 99 T/A, or any other LS1 for that matter. I first tried the "cutting the green wire" mod, but that didn't work for me. Maybe there was a difference between the LT1 and LS1. So I soldered back the wire and just did what I posted above.
[ February 10, 2002: Message edited by: SS 414 ]</p>
__________________
George
2000 Camaro SS
FastLSX
Old 02-11-2002, 07:20 PM   #11
Trader Rating: 0
I just did mine! The top and bottom didn't work so I used both bottom ones (closest to the nose of the car) works great!
__________________
mods so far&gt; Mezeire wp,billet grille, gms maf,K&N fipk, cognito 12" lift, super swamper 38's, weld mountain crushers, kodiak sidewinder automatic steps, thunder tb, gms maf, K&N fipk, asm headers, true duals, LS1 fans, thunder 212/218 558/563 112lsa cam soon!
Old 02-11-2002, 07:37 PM   #12
BIGBOS's Avatar
Trader Rating: 0
Terry did you use the the above method or did you cut the green wire....
And can someone tell me the # on the fuse so I know which one to yank out... <img src="gr_stretch.gif" border="0">
__________________
Old 02-11-2002, 08:06 PM   #13
Trader Rating: 0
I just pulled out the fog light fuse and there is four pins on it, jumper the 2 front ones together (ones toward the nose of the car)
the fog light elay is in the fuse box under the hood and the fog light one is listed on top of the cover
__________________
Old 02-11-2002, 08:37 PM   #14
Texas Director
mmiller's Avatar
Trader Rating: 1
I just did it too. Works perfect, just like Terry said. I used some solid #18 or #20 wire.
Does anyone know how to keep the low beams, high beams, and fog lights on at the same time?
mmiller is offline   Reply With Quote
Old 02-11-2002, 09:24 PM   #15
Trader Rating: 0
wow.. thanks for the tips.. i was wondering myself and someone got to it before me!
Bobby C 01TA is offline   Reply With Quote
Old 02-11-2002, 09:44 PM   #16
Trader Rating: 0
ok guys here is another question.
Does anyone make brighter fog light bulbs?
__________________
Old 02-12-2002, 01:00 AM   #17
SS 414's Avatar
Trader Rating: 0
[quote]Originally posted by mmiller:
<strong>I just did it too. Works perfect, just like Terry said. I used some solid #18 or #20 wire.
Does anyone know how to keep the low beams, high beams, and fog lights on at the same time?</strong><hr></blockquote>
High/Lows
Zurbo posted it, it is the 2nd to last post on the page
[ February 12, 2002: Message edited by: SS 414 ]</p>
__________________
George
2000 Camaro SS
FastLSX
Old 02-14-2002, 10:51 AM   #18
Trader Rating: 0
[quote]Originally posted by terry99ta:
<strong>ok guys here is another question.
Does anyone make brighter fog light bulbs?</strong>
<hr></blockquote>
Go to www.prostreetlighting.com Look at the 893 Xenon bulbs. They are direct replacement for the stock 880s.
__________________
2000 White Ws6 M6
SloWhite is offline   Reply With Quote
Old 10-05-2002, 05:36 PM   #19
Trader Rating: 0
Just for reference, I've got the 4 beam brights and fogs with brights mods up on my website now.
Cox dumped roadrunner so none of the picture links work in my older posts from ls1.com.
You can find the new mods page Here
<img border="0" alt="[Camaro]" title="" src="graemlins/camaro.gif" />
<small>[ October 05, 2002, 04:37 PM: Message edited by: Zurbo ]</small>
__________________
Zurbo's F-Body - 1998 Camaro SS # 2395
Red/Black with grey leather, Monsoon and T-Tops.
A4 with 3:23 Auburn.
Whisper Lid, Trans-Go Shift kit, and Quadtip B&B Triflow.
FRA, 6-Beam Brights.
Click here for my 98 Camaro SS website.
Click here for my 72 Super Cheyenne website.
Zurbo is offline   Reply With Quote
Old 10-05-2002, 08:02 PM   #20
Seņor Member
unit213's Avatar
Trader Rating: 0
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Zurbo:
<strong>Just for reference, I've got the 4 beam brights and fogs with brights mods up on my website now.
<img border="0" alt="[Camaro]" title="" src="graemlins/camaro.gif" /> </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Thanks Zurbo. I'm going to do this mod tomorrow by following your instructions.
Dan
__________________
630rwhp | 600rwtq | Fquick
Modified by Livernois Motorsports
unit213 is offline   Reply With Quote
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
LS1TECH - Archive - Top
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
Advertising - Terms of Service - Privacy Policy - JOBS
