Click here to visit LS1Tech
Click here to visit Performance Trucks
Click here to visit Mod Motor Tech
Click here to visit Modern Hemi
LS1Tech Wiki
LS1TECH
Go Back   LS1TECH > CHASSIS, SUSPENSION, APPEARANCE > Stereo & Electronics
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into LS1Tech.com, click logo to login
Old 10-08-2009, 07:43 PM   #261
Trader Rating: 0
for those taht arent comfortable doing this mod them selves i can do it for a small fee
pentavolvo is offline   Reply With Quote
Old 10-09-2009, 01:27 AM   #262
2002 Pontiac Firebird
pheer's Avatar
Trader Rating: 3
if you're in the Houston area of Tx and wold like this done to your vehicle, i can be of help. jus shoot me a PM
i have successfully done this to both my 2002 Trans Am, and a friend's 2000 Z28 with no problems at all along the way
__________________
What's the quickest way to 500rwhp NA?
2002 BSM Firebird Trans Am A4 - 1 of 344 -Lid, Smooth Bellows, Ported TB, LCAs w/Relo. Brackets, PHB, Upper PHB Relo., !GF, more on the way...
pheer is offline   Reply With Quote
Old 10-09-2009, 11:40 AM   #263
2000 Chevrolet Camaro
Trader Rating: 0
i could really use some help on this i tried to split into all of them and nothing. if anybody knows the wiring of this radio i could use the help
__________________
2000 Chevy Camaro Pacesetter headers, Magnaflow cat, Flowmaster catback, K&N FIPK, BMR strut brace, UMI subframe connectors, Optima battery, MSD wires, KYB AGX shocks, Eibach Springs, 99 Corvette rims
swaggard is offline   Reply With Quote
Old 10-09-2009, 01:35 PM   #264
Trader Rating: 0
is the jack wired correctly? what have u done to verify its not working? you know a cd has to be in and playing for it to work
Old 10-09-2009, 04:44 PM   #265
Trader Rating: 0
if you look at the page before this i have a pic of the way mine is wired. i tried the 1 and 3 wire on both. i played a cd and when i put a plug in the jack the cd stops and and a few seconds later the cd player says err and the cd comes out. no sound with the ipod plugged in
__________________
Old 10-10-2009, 08:21 PM   #266
Trader Rating: 0
what do you think volvo. what wire do you think it is.
__________________
Old 10-10-2009, 08:39 PM   #267
Trader Rating: 0
If it's showing an ERR on the CD player then it does sound like a wiring issue with something other than the audio wiring being tapped into. Is this that stock radio that came with the car, do you have a picture of the front and does it have a date on it? The circuit board is a bit different than I recall, the placement of the connector and the chip in the middle.
Compare to my 98:
http://www.ls1tech.com/forums/6865143-post5.html
Or to this 2000:
http://www.ls1tech.com/forums/7692161-post45.html
There should only be one wire coming from the CD module, so it should be easy to track down, and although the wire colors seem to change over the years the audio signal positions have stayed the same, and yours look right based on that (the one on the right).
Here's how to probe the connector for the audio pins:
"I had a stereo connector and hooked into a 12v power supply, you may need to run it off the car's connector. I made a probe by cutting off the end from an old set of headphones, and hooking the left/right channels together, and the left/right grounds together, and then each to a paper clip, plugged it into a female/female adapter, and then into a set of speakers. You could also just cut off the end of some headphones and probe using the headphone ends, just be careful because you can get some really loud tones. Put the ground probe onto the metal case of the stereo, and then tap each pin looking for sound"
__________________
1998 Camaro Z28
Red A4, T-Tops, 3.23, Fully Loaded, 24,000GVW B&M Transmission Cooler, Midwest 3600 2.5STR Torque Convertor, SLP Airlid, SLP Loudmouth Exhaust with Dynomax Bullet, BMR Boxed Subframes, BMR LCA Brackets, DMS Springs, Bilstein HD Shocks, JL Audio Stealthbox, Firebird Power Antenna
http://www.jason-novak.com
Jason Novak is offline   Reply With Quote
Old 10-10-2009, 08:41 PM   #268
Trader Rating: 0
no i dont have a pic right now but the front looks like a regular 2000 cd player
__________________
Old 10-31-2009, 12:49 AM   #269
Trader Rating: 0
Just curious if anyone had traced down the leads heading to the amplifier IC in the radio. (or possibly pre audio processor IC) but after whatever the audio mux is? This would possibly enable not needing to have a CD PLAYING TO get AUX audio?
Spektre
Spektre is offline   Reply With Quote
Old 11-06-2009, 10:33 AM   #270
Trader Rating: 0
Default Will this work on a 2003 corvette z06 w/o cd changer
From what I have gathered so far, I believe this will work on my 2003 c5 z06 w/o cd changer
Can someone confirm being successful with this car?? Thanks
klly0050 is offline   Reply With Quote
Old 11-06-2009, 10:30 PM   #271
Trader Rating: 0
100% will work on all year c5 radios cd changer or not
Old 11-09-2009, 05:37 PM   #272
02b4ccamaro's Avatar
Trader Rating: 2
i what to do this on my 02 2500hd but i want to use the aux button that is for the tape player, does anyone know what wires i would have to tap in to to do that.
__________________
02 z28
lid, smooth bellows, ss ram air, lts, ory, hp tune.
(tr230/224 111lsa waiting to install) 12.67 @111
02b4ccamaro is offline   Reply With Quote
Old 11-09-2009, 07:14 PM   #273
Trader Rating: 0
if it doesnt have a tape player currently and u want to somehow utilize the aux button it wont work
Tags
1998, add, auxin, camero, car, cd, converting, forum, input, ipod, jason, line, ls1, mp3, novak, player, port
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
LS1TECH - Archive - Top
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
Advertising - Terms of Service - Privacy Policy - JOBS
