First Jason thanks for the write up and answering all these questions.
I would like to do this for my 3rd Gen using a cassette HU.
I circled the place I think I need to cut, #1 (Blue) and #3 (Red) and then follow all the other instructions, just wanted to make sure if you have time to look.
Here is what the front of the radio looks like
If you give me the go ahead next stop is radio shack.
I currently have put in an after market HU to get the MP3 jack but it does not look near as good as a stock HU and I am keeping the car as stock appearing as I can.
If there is any doubt you can test it by cutting off the end of an old set of headphones and connecting the ground and the left or right to paper clips and probing the pings while it's playing, that's how I discovered them
__________________ 1998 Camaro Z28
Red A4, T-Tops, 3.23, Fully Loaded, 24,000GVW B&M Transmission Cooler, Midwest 3600 2.5STR Torque Convertor, SLP Airlid, SLP Loudmouth Exhaust with Dynomax Bullet, BMR Boxed Subframes, BMR LCA Brackets, DMS Springs, Bilstein HD Shocks, JL Audio Stealthbox, Firebird Power Antenna http://www.jason-novak.com
Holly Crap, I even remember reading that part, I think it was over load.
Thank you very much, and man that was fast I went to send a link of this to a friend who I think would be interested in doing it and when I came back to get the link there was an answer already, wow, it 12:24 where I am, I need to go to bed now, alarm goes off at 5:20.
If you have a changer you can tap into the changer's cable so you don't need to open the the head unit. You'd use the same concept and jack listed here, but I don't know the specific wiring, I know there's another thread on it.
Just did it on mine and I'm so damn happy!!! Mine had only one long connector ('98 without CD changer) and I used the one furthest to the back of the unit and the 3rd from it. I just need to figure out where to mount the connector, I have it looped up in my glove box for now till I can figure something out.
__________________ '98 T/A ... Forged 6ltr, FAST90/90, MS3, T56/McLeod swap, 4" Mufflex, Koni/Strano/Ground Control ... etc., etc. etc...... For Sale! My Fquick siteCustom Installs ... t-top conversion? LS1/T56 swap? just ask...
I can't find the thread anywhere. All I am bringing back is some adapter. Nothing as detailed as you posted. I might just do your way.
Check another one done, works awesome!
I did this on my third gen, I prefer the look of a stock radio in the firebirds, especially at night.
Thanks again Jason.
Thanks again Jason.
Looks good
is thre any way to tap into something so it can charge at the same time?
__________________ 2002 BSM Firebird Trans Am A4 - 1 of 344 Lid, Smooth Bellows, Ported TB, LCAs w/RBs, PHB, U-PHB Relo., LTs, 3" TDs, TunedbyFrost, Poly Mounts, Novak Jack, HIDs, NGK, MSD, !AIR, !GF, running out of bolt-ons...
"...if by stock you mean, nothing close to stock, then yes, it's still stock..."
i agree.. i was thinking that some kinda dock that had both would be really cool, but on the iphone (which is what i'll be using this for 99.9% of the time) the aux out is on top, and the charge port is on the bottom..
__________________
-Bill 2002 NBM SS #8566, 6 speed, 3560 lbs.. Fquick
Parts Needed: Fogs and HIDs, SS third brake light. PM me..
