Click here to visit LS1Tech
Click here to visit Performance Trucks
Click here to visit Mod Motor Tech
Click here to visit Modern Hemi
LS1Tech Wiki
LS1TECH
Go Back   LS1TECH > CHASSIS, SUSPENSION, APPEARANCE > Suspension & Brakes
Old 11-20-2008, 02:50 AM   #1
Zureal's Avatar
Trader Rating: 0
Send a message via AIM to Zureal Send a message via MSN to Zureal Send a message via Yahoo to Zureal
Default BMR or UMI Suspension Package???????
I want to get a complete suspension handling package instead of mismatching parts. Want a good road race/street car. But everyone is directing me to ether the BMR HPP004 one ( http://www.bmrfabrication.com/4F-PACKAGES.htm ) or the one from UMI one ( http://www.umiperformance.com/FBR003?category_id=162 ) . witch should i go with? people are telling me this one is better or that one is better so i do not know witch one to get plzzzz help!!!! What are the proes or cons of each if any??? Thank you for your input
Zureal is offline   Reply With Quote
Old 11-20-2008, 06:16 AM   #2
Bucksbadz's Avatar
Trader Rating: 0
There are really no draw backs with either package, and both are worth the money and the quality is pretty much identical. The UMI package comes with alot better shocks then the BMR, plus better springs imo, and lighter swaybars. For the 300 or 400 dollar differance i would go with the UMI package just because of the better shocks, koni's are worth it.
__________________
Surgeon General says nothing about smoking a ford.
http://i229.photobucket.com/albums/e...ybluejd4-1.jpg
02 NBM Z28. Pacesetter midlenghts, underaxle duel exhaust, slp airlid, hypertech programer, 1.2 strano drop springs, and eibach anti roll bars, UMI LCAs with relocation brackets, Adjustable Panhard Rod, Adjustable Torque Arm, Strut Tower Brace, and Boxed Subframe Connectors.
Bucksbadz is offline   Reply With Quote
Old 11-20-2008, 06:22 AM   #3
michaelg589's Avatar
Trader Rating: 1
I have UMI LCAs and PHR. also Stranos springs and KONIs. Go with UMI, they sell stranos springs, stranos bars and KONIs. KONIS ARE THEY BEST SHOCK FOR OUR CARS WITHOUT A DOUBT. I am amazed at how well my car handles with them.
__________________
2000 Trans Am M6, Few mods - 326rwhp, 338rwtq... 1/4 mile: 13.030@109.5mph, 2.03 60ft.
michaelg589 is offline   Reply With Quote
Old 11-20-2008, 08:22 AM   #4
Fast_94_Z's Avatar
Trader Rating: 9
Send a message via AIM to Fast_94_Z Send a message via MSN to Fast_94_Z Send a message via Yahoo to Fast_94_Z
i would go with the umi stuff. sam strano does a lot with of things when it comes to handle and has helped them setup a real nice package deal. you'll get your moneys worth for what your looking to do.
Fast_94_Z is offline   Reply With Quote
Old 11-20-2008, 11:00 AM   #5
z28bryan's Avatar
Trader Rating: 7
The UMI package there is far superior to the BMR package. It's more expensive true but you are getting Konis which Tokicos are not even in the same field as Konis. You're also getting a better balance of front/rear swaybar with the UMI. The other things like the rod/poly vs poly/poly PHB and the different springs will be personal preference.
Also, what do you mean by mismatching parts? Just because a parts vendor puts together a package, doesn't mean they put together the right parts. I think the Tokicos are probably a mismatch with the BMR springs. BMR should offer a Koni/BMR spring package. At that point the prices between packages will probably be similar.
__________________
1999 Z28 - 400/381 rwhp/rwtq - 224/228 custom cam, ported Z06 heads, forged rods/pistons, some bolt ons, koni/strano shocks/springs, 35mm front solid, 21mm rear solid swaybars, 17x11 zr1 wheels 315/35/17 Nitto 555r tires all around, boxed SFCs, stock 10-bolt, -1.5 degrees of front wheel camber
z28bryan is offline   Reply With Quote
Old 11-20-2008, 12:42 PM   #6
LS1TECH Sponsor
Trader Rating: 23
Let me help you out. There are a lot of options available. And you don't necessarily need to buy a package. It depends on what you are after as a result, and for me to know that and to help you with a recommendation I'd need to speak to you by phone.
I took my packages down because we out of stock on some items for a few weeks (just being honest here). They are coming back in stock, but that doens't matter if you don't need all the part in a kit (and many folks don't). Even if you end up getting them all, doing a setup more methodically while not as good for the vendor (no single big sale) is usually better for the customer because you can see how each part works and makes the car drive better. And you can stop when you get to what makes you happy. You don't overbuy...
You see posts from others that are Strano Performance Parts customers. And I'm the only vendor here these days who actually turns corners. And in fact aside from results I have, and the customer's word of mouth we have articles about cars I've done complete with driving impressions and lap times too to show how the suspension work I do works.
Not every "package" is right for every person. I also sell Tokico, and Bilstein (and others)... not just Koni. If you want the best working car you can get, Koni's are the biggest key. Bigger than springs or bars, but those do have effects too.
I'd be happy to talk to you about options... and more importantly why I think the way I do and explain how the stuff works. What I'd recommend you do it call all the vendors you are thinking about, and talk to them. Ask questions, and see what questions they ask you.... Then you can make a better decision.
__________________
Sam Strano
SCCA National Champion (x5)
814-849-3450
www.stranoparts.com
I value and appreciate your continued support. We strive to offer the best parts and the best advice,
backed up by proven results and happy customers.
Sam Strano is offline   Reply With Quote
Old 11-20-2008, 01:15 PM   #7
Zureal's Avatar
Trader Rating: 0
hmm.... well... if u realy want me to call to get spacifics i will. If i doint then i think ill go with the UMI setup. And if i do call u wana talk to u spacificly, how can i reach u? I am still fairly new at working on cars and modifing them so i prefer to talk to people that realy know what they are talking about then just assuming anyhting Thx for the responses everyone mutch appreciated.
So... wares that phone # Sam Strano?
Old 11-20-2008, 01:20 PM   #8
LS1TECH Sponsor
Trader Rating: 23
The phone number in in my signature....
And if you want a setup that suits *you* best, then it's best to talk about what you want, and what you know. Parts are used to do a job, if the job doesn't need done why have the part?
__________________
Sam Strano
814-849-3450
www.stranoparts.com
Old 11-20-2008, 06:08 PM   #9
Zureal's Avatar
Trader Rating: 0
good point, well then ill probibly call u soon to talk about it. cant wait, wana kick the crap out of my freinds dads ZO6 hehehe
Old 11-20-2008, 08:40 PM   #10
MUSTANGBRKR02's Avatar
Trader Rating: 22
Quote:
a witch...but go UMI
__________________
02 T/A vert with a big hood
MUSTANGBRKR02 is offline   Reply With Quote
Old 11-20-2008, 09:32 PM   #11
Zureal's Avatar
Trader Rating: 0
bla! spelling
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Alphabetical sponsor list
Speed Inc.
Fast Toys
ByunSpeed
Forced Inductions
Air Flow Research
Burkhart Chassis
EFI Alchemy
Nitrous Express
Full Throttle Speed
Painless Performance
Patriot Performance
Afterthoughts Auto
Livernois Motorsports
Finish Line Performance
Exotic Performance Plus
Maryland Speed
American Racing headers
WS6 Store
School of Automotive Machinists
Speed South
Katech Engine Development
Yank Torque Converters
Nasty Performance
Speartech Fuel Injection Sys
Performance Oil Technology
Race Proven Motorsports
Quick Time Performance
West Coast Cylinder Head
Speed Engineering
Car Shop Inc
Rapid Motorsports
Specialized Stainless
Finish Line Transmissions
Harris Speedworks
Late Model Engines
LG Motorsports
SLP
MPH Motorsports
Late Model Racecraft
Midwest Chassis
Madman Racing
Kee Audio
TT Performance
LSx Tune
Kooks Custom Headers
Slowhalk
Circle-D Converters
TomZ Wheels
Competition Clutch
UMI Performance
Trifecta Performance
Canadian Performance
Xtreme Horsepower
Cartek Racing
Tick Performance
Racetronix Fuel Systems
G-Force Motorsports
SJM Manufacturing
Texas Speed & Performance
Tropi-Care
Redline Goods
Nano Nitrous
Performance Auto Fabrication
LM Performance
Straightline Performance
Century Transmission
VFN Fiberglass
Total Engine Airflow
Dyno Tune
Vengeance Racing
Speed Tweekerz
Nitro Dave's Nitrous Outlet
New Era Performance
Mast Motorsports
Nitrous Oxide Systems
Southern Car Parts
Race Engine Development
Advanced Induction
Pavlock Performance
World Products
Auto Parts Firm Online
CarsDirect
Wolfe Racecraft
Futral Motorsports
BMR Suspension
PerformaBuilt Transmissions
Spohn Performance
Discount Tire
Faster Proms
Diablo Sport
Scoggin-Dickey Parts Center
Cunningham Motorsports
Lonnies Performance
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
Advertising - Terms of Service - Privacy Policy - JOBS
