Click here to visit LS1Tech
Click here to visit Performance Trucks
Click here to visit Mod Motor Tech
Click here to visit Modern Hemi
LS1Tech Wiki
LS1TECH
Go Back   LS1TECH > CHASSIS, SUSPENSION, APPEARANCE > Suspension & Brakes
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into LS1Tech.com, click logo to login
Old 10-01-2009, 10:56 PM   #221
Trader Rating: 0
Default cheap big brake kit
hi, id like to know if its possible to find really cheap big brake kit for infiniti g35 coupe 03-07.
Front and Rear with big calipers..
w/ 14"-15" rotors and pads etc
please let me know
thanks
macman514 is offline   Reply With Quote
Old 10-02-2009, 12:37 AM   #222
Trader Rating: 3
Send a message via AIM to imma_stocker
please let me know
thanks
So you come onto LS1tech.com instead of my350z.com
You would have better luck on a foxbody forum, I think you share the same lug pattern.
__________________
2008 Subaru STI M6 310awhp/340awtq (that's ALL whp)
2002 Z28 M6 415whp/390wtq (for now)
2000 C5 M6 all stock <14k miles
imma_stocker is offline   Reply With Quote
Old 10-02-2009, 09:10 AM   #223
JasonWW's Avatar
Trader Rating: 1
Just about any aftermarket kit will cost you big bucks. If you want a cheap solution you'll need to build it yourself.
Your best bet is to raid the Nissan/Infinity parts bin and see what parts might interchange with your car. Check older and newer Skyline brake parts as well.
The main thing is to hit up the proper forums. I'm sure your not the only person wanting bigger brakes for that model of car. It's through combining knowledge that you can find a solution.
__________________
Qoute from 99345hp "Hell yeah Jason, tear that thing apart."
I do unique mods for the hell of it, so don't question my reasons.
The 99 TA is now riding on airbags front and rear for only $335. More parts to be added later. Install Thread
Super Low Project (plus other links)
JasonWW is offline   Reply With Quote
Old 10-02-2009, 11:06 PM   #224
Blevinator's Avatar
Trader Rating: 0
Has anyone commented on the difference this kit made over stock?
Does it cause the car to feel unbalanced during braking without the rear setup??
__________________
2001 T\A Vert
MS3 Cam,Pacesetter LT's, ORY, Magnaflow (No Cats) with Corvette dual tips,Suncoast WS6 hood, Suncoast Ram Air Kit, Speed Density tune,Lou's Short Stick, NGK TR55's,Deka racing battery,160 degree thermostat,Spohn Delsphere panhard bar,Spohn DelSphere LCA's,BMR LCA relo brackets. Bilstein shocks\struts,
18" C6 Z06 wheels, Vredestein 295's, 275's, Katzkin leather seats
417 RWHP Much more to come!
Blevinator is offline   Reply With Quote
Old 10-03-2009, 09:09 AM   #225
JasonWW's Avatar
Trader Rating: 1
Wink
The people who have done this upgrade all say positive things. It slams you to a stop. The balance may be better than stock. I'll let them chime in personally. If their lazy then I'll dig up their comments on their installation threads and post them here.
__________________
Old 10-04-2009, 05:33 PM   #226
1998 Pontiac Trans Am
Wesmanw02's Avatar
Trader Rating: 1
Definitely not.
The stock brake system is biased towards the rear, meaning often times the rears grab hard enough to kick in the ABS even before the fronts do on a hard stop.
With these big front brakes, the front brakes are much stronger, so when you dive into the pedal you get a much more balanced brake effect. The fronts slow the car down A LOT by the time the rears start to kick the ABS in.
I've put my CTS-v system through its paces, and I think the balance is excellent.
Wesmanw02 is offline   Reply With Quote
Old 10-04-2009, 06:36 PM   #227
Blevinator's Avatar
Trader Rating: 0
Quote:
Originally Posted by Wesmanw02 View Post
Definitely not.
Thanks Wesman!!
What was the difference vs stock?
30%,50%? Shorter stop times?
Also, I have heard many comment about the added weight of
these systems over stock calipers,rotors.
Anyone know how much more the rotors, calipers weigh than the stock setup?
Thanks in advance!!
__________________
2001 T\A Vert
Old 10-04-2009, 07:28 PM   #228
Tudds's Avatar
Trader Rating: 4
Send a message via AIM to Tudds
Do you have to put spacers on the caliper?
__________________
02' Limited Edition M6 12.69@110.72 1.9 60ft-Stock with DRs
1998 Jeep Grand Cherokee
LIFBA Member 2006
Tudds is offline   Reply With Quote
Old 10-05-2009, 04:41 PM   #229
Wesmanw02's Avatar
Trader Rating: 1
Thanks Wesman!!
Thanks in advance!!
Hard to give a specific percentage. Its a huge improvement though, when you really hit the brakes the car decelerates so much faster than stock. The faster you go, the more you notice the improvement. You can brake into a turn much later with this setup, since it slows down so much quicker and efficiently. I'm sure the stopping distances are much shorter than stock as well.
As for weight, the only thing that really weighs more is the rotors. They are quite heavy, but they are designed that way since they are so large and need to dissipate heat and resist warping. The CTS-V calipers are aluminum like the stock calipers, so I doubt they way much more, if any. In fact, they are probably lighter because you eliminate the stock steel caliper bracket. In total this upgrade probably adds 10-20lbs over stock. Nothing significant.
Quote:
You just need to use washers between the caliper and spindle to properly center the caliper over the rotor.
Tags
10bolt, 13, big, brake, brakes, cheap, chevy, colorado, conversion, cts, inch, kit, kits, rotors, silverado, ss, super
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
LS1TECH - Archive - Top
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
Advertising - Terms of Service - Privacy Policy - JOBS
