__________________ 2000 WS.6 M6 (SLP Lid l Ported TB l LS6 Intake l Long Tube Headers l Magnaflow CB l Frost Tune l Koni 4/4's l Strano Springs) 13.3@110.9mph with a 2.2 60' before Headers, intake, and tune. Up next, Strano Sway Bars l M/T ET Streets l Monster Clutch l 75 Shot
Great vid, very good, I will be rewatching this when I install mine.
We need videos like this for all the right ups that are here, great work BlueKnight
__________________ _____________________________________________
Black 2001 WS6 A4
Lid, TB, CAI, GMMG, Koni, poly bushings & endlinks, relo brackets, HPS, WW GFX & Wing, HID, 10" sub and some small custom touches
Plans include:
LT, E-cutout, pulleys, sways & watts link, and tempted by a stall, 3.73 or a little juice....
Thanks a lot Blue Knight. Great video, don't be shy to make it longer. I would of liked to see the disassembly and assembly of the new spring, but I will figure it out. Probably pretty simple.
Thanks.
__________________ Timmy LS1 Compiliation - My 2000 Z28
Red Foreman: "The mustang's front end is problematic; get yourself a firebird."
Thanks.
Yeah, from the point I end it it all goes back together the way it came apart, it might seem a little intimidating or confusing when you are watching the vid, but as you are actually doing it, it all makes sense.
I had never worked on any vehicle's suspension in my life and did the entire install reading an article I printed off the internet.
Ok so put the springs in the rear no prob and the DS was really easy too. Then came the pass side.
Everything went 2x as fast as the Driver side then BAM major problem. The 15mm nut at the top of the strut assembly was rusted to hell! WTF. Budged it with a 15mm deep socket but top of the shock started to move with the nut. So deep sock is no use now. Using a 15mm box wrench and clamps on top is getting me no where!!!
Please someone tell me what my options are now!?!?
I am encountering the same problem with both shocks. I soaked 1 of them with deep creep the night before. (did not plan on doing this today) I was not aware of the fitting on top of the stud that is above the shock nut at first.
I wound up taking a thread chasing kit and running it down the threads to clean the remaining excess of rust and to reshape threads up to the nut. The nut came off easy after slight pressure. I am off to let the 2nd soak with some penetrating lube now.
__________________ Motor blown! Snapped rod.
(LE3/4 Forged 383 in the works)
Ok so anyone have any torque specs for the front and rear suspension?
IE: the stuff that was un-torqued during the install? I know the nut at the top of the shock is supposed to be 33ft lbs but what about the other stuff?
I did the install already but since I recently got a nice torque wrench I'd like to go back and spec everything out.
Not sure, I just tightened everything down good and tight.
awesome video man, I was trying to do the front by just winging it! I didnt disco the ball jount or sway bar and I couldnt do it. I removed the stock spring with out a spring compressor, I thought I would have to get a compressor to install. Now I see how it should be done.
WTF KONI? how come these struts are so good and come with the worlds worst instructions? for 200 per strut u would think they would be a bit clearer of instructions.
For the record, this is why I'm adamant about trying to inform folks about how I handle Koni sales/customers. The instructions do suck, but any customer who bought their Koni's from Strano Performance Parts is free, hell... encouraged to, call me when the shocks are in hand so I can help with the setup and installation details.
There are tricks I know that I've unfortunately had to keep closer to the vest because I keep getting blindsided by being too open too early (folks take the information and run). All those details all happily passed on to my customers.
__________________ Sam Strano SCCA National Champion (x6)
SCCA ProSolo Overall Champion-2009
SCCA ProSolo Class Champion (x5) Strano Performance Parts
814-849-3450 www.stranoparts.com
rear lower shock nut- 66ft/lbs
upper ball joint nut- 39 ft/lbs
front upper shock nut- 32 ft/lbs
front upper shock bolt- 37 ft/lbs
front lower bolt/nuts- 48 ft/lbs
stabilizer bar link bolts/nut- 17 ft/lbs
