i have the 2010 SS camaro brembo's on backorder right now.
they're the same calipers as the caddy, they just say camaro on them. but i went front and rear, as soon as they get here i'm going to make brackets for atleast 3 cars around my area.
same calipers yes but might have different mounting points.
__________________ no replacement for displacement.. end of story
already got the rear CTS-v calipers and they won't work without MAJOR MAJOR modification, basically its not worth it. however, you might be able to get the rears from a new camaro, but again i have no idea. i just powdercoated my stock rears to match and got matching rear drilled rotors. it looks like i have a BBK on all 4 wheels!
__________________ 1999 Pewter Camaro Z28 M6 ENGINE: 404ci forged monster, oh and with a big turbo hanging off the front! SUSPENSION/BRAKES: Custom Brembo Big Brake kit w/ Hawk pads, Edelbrock Adjustable Coilover front shocks with Eibach springs, Hotchkis STB & Rear springs, full Energy Suspension kit
^ I'd be interested to see what you can do with them. I'd love to have them on all 4 corners. My next relatively large project is swapping a disk brake rear end into my 95 and installing my front CTSV setup.
Pics?
Someone got a c6 rotor to fit and the e brake to work... maybe a new bracket needs to be made
Wilwood also makes a larger rear kit for f-bodies...it's advertised as 93-97 iirc, but the rear brake setup is the same for both lt and ls years. But you're probably going to want a brake proportioning valve installed if you change the rear brake setup
__________________
--1967 Camaro SS
--2002 Camaro SS #9510
--2002 Corvette Z06
-SCCA T-1-
-Cal Club #24-
Off Season means repair season
also im sure the will wood rears cost more than our ctsv fronts
do a search here, people have bought sold them. The thing with Wilwood compared to other companies like StopTech, is Wilwood is much much cheaper. I can't remember pricing, but for what it was, it wasn't that expensive really. Just trying to give another alternative that is already out there to help save time and possibly $ to re-invent the wheel..
__________________
--1967 Camaro SS
--2002 Corvette Z06
-SCCA T-1-
-Cal Club #24-
First question is why do you want to put a larger rear brake on a 4th gen? I still have no idea why people think they need bigger brakes back there. They're already too big for the car, so why go bigger?
Your cosmetic change only will most likely cause more problems then what it's worth. Go into a corner with too much rear brake, then get on them a bit too much....well I have fun in the grass, tree, or whatever is near by to slow you down.
__________________ 00 Black Formula HT-Picture
What's the Funny Whistle coming from your engine? Ah, yeah, my alternator is going out. Dyno Graph
97 Civic-Picture
"24 hours in a day - 24 beers in a case. Coincidence?"
- Steven Wright
which is why I mentioned a brake proportioning unit. But most people who want to change it i think do it for the looks..
__________________
--1967 Camaro SS
--2002 Corvette Z06
-SCCA T-1-
-Cal Club #24-
True enough. I honestly think a fbody needs a prop valve from the factory to turn down the rear brakes.
And they may be doing it for looks, but looks and brakes should not be mixed. IMO.
97 Civic-Picture
- Steven Wright
