Click here to visit LS1Tech
Click here to visit Performance Trucks
Click here to visit Mod Motor Tech
Click here to visit Modern Hemi
LS1Tech Wiki
LS1TECH
Go Back   LS1TECH > CHASSIS, SUSPENSION, APPEARANCE > Suspension & Brakes
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into LS1Tech.com, click logo to login
Old 09-26-2009, 06:27 AM   #21
UnZFeat'd's Avatar
Trader Rating: 1
Send a message via AIM to UnZFeat'd Send a message via Yahoo to UnZFeat'd
Quote:
Originally Posted by Sam Strano View Post
Um... I've not had one noise complaint either, including my own on the Watts link. In fact, even on rod-ended PHB's, the noise is always much less than with rod-end LCA's. That's sort of the trade-off one makes for no bind.
Sam! Waiting for you to chime in. What do you think of these LCAs then? What should i do to quiet them down besides keep my mouth shut from complaining? If you say they should be this noisy then, thats i guess what i have to deal with. Other than that, ill entertain any kind of ideas that you have. Ive been waiting to hear from the authority. Mostly sure its from the LCAs not the watts.
__________________
1999 Chevy Camaro SS M6
Pacesetter LTs, LS6 intake, TSP TDs w/ Dynomax bullets, Racetronix 255lph w/ hotwire, 200amp alt, tb bypass, !EGR!, !AIR!, !CAGS!, NGK BR7EFs, MSD 8.5mm, Whisper lid, K&N filter, SLP smoothe bellows, UMI adj rod LCAs, Fays2 watts Link, Strano Bilstein HD shocks, UMI adj tq arm, 75 shot of good luck
UnZFeat'd is offline   Reply With Quote
Old 09-27-2009, 09:57 AM   #22
LS1TECH Sponsor
2010 Chevrolet Camaro
My Garage
Lonnies Performance's Avatar
Trader Rating: 4
If you are having noise, I doubt it is from the watts link. Mine is totally quiet on my daily driver. They are made with high quality rod ends & should be quiet for a very long time.
As for rod ended lowers, you have to expect some noise due to the shock loads on them from every bump in the road. If you invest in some very expensive teflon lined rod ends, it will be much quieter, but expect periodic replacement to keep it that way.
I have another car with rod ends in every suspension point front & rear & it sounds like you dropped a handfull of quarters on a concrete floor when you hit a bump. The price you pay for function over comfort...
__________________
Lonnie Pavtis
Lonnies Performance Automotive
http://www.lonniesperformance.com
Celebrating our 10th year - 1999-2009
Specializing in custom fuel systems, fuel injection components,
suspension & all of your supercharging needs.
(724) 322-8505 9:00am-11:00pm (eastern time) weekdays & weekends
Lonnies Performance is offline   Reply With Quote
Old 09-28-2009, 01:50 PM   #23
LS1TECH Sponsor
Trader Rating: 29
Quote:
You could try a higher end rod-end. QA1's are tough, but not the most tight tolerance wise. Might want to look at an Aurora or FK. I'm sure it's just rod-end noise.
__________________
Sam Strano
SCCA National Champion (x6)
SCCA ProSolo Overall Champion-2009
SCCA ProSolo Class Champion (x5)
Strano Performance Parts
814-849-3450
www.stranoparts.com
Sam Strano is offline   Reply With Quote
Tags
binding, bushing, daily, driven, ends, fays2, groaning, link, ls1com, problems, quiet, rod, rubber, sound, watts
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
LS1TECH - Archive - Top
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
Advertising - Terms of Service - Privacy Policy - JOBS
