Click here to visit LS1Tech
Click here to visit Performance Trucks
Click here to visit Mod Motor Tech
Click here to visit Modern Hemi
LS1Tech Wiki
LS1TECH
Go Back   LS1TECH > REGIONAL FORUMS > Texas Members
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into LS1Tech.com, click logo to login
Old 10-26-2009, 01:55 PM   #1
kmgsix08's Avatar
Trader Rating: 12
Default Replacing the Power Steering Rack on my '00, need help!!
Okay, so my power steering rack is popping when I turn the wheel back and forth. My first thought was the outer tie rods, so I picked up a pair. Still popping after the install, so now it's pretty much narrowed down to either the bushings or the gear box. I said screw it and just bought an entire rack. I was told that the '01-'02 F-Body's came with a fluid cooler or something to keep the fluid from getting too hot and messing up the gear box..? Does anyone know if one of these coolers can be installed on a '00 F-Body? Anyone have any knowledge in this area?
__________________
2000 Camaro Z28 M6- ss hood/spoiler, chrome z06's, hooker long tubes, hooker catback, texas speed catted y-pipe, tuned by texas speed and performance, cme tips w/ valance, slp subframe connectors, slp strut tower brace, slp cold air intake, eibach pro-kit, bilstein shocks revalved by sam strano, adj. panhard bar, lca's, relocation brackets, short shifter w/ C6 knob, other small appearance and interior mods
kmgsix08 is offline   Reply With Quote
Old 10-26-2009, 02:32 PM   #2
Trader Rating: 79
Send a message via AIM to ROCNDAV Send a message via MSN to ROCNDAV Send a message via Yahoo to ROCNDAV
I thought the power steering cooler was just an option. You don't need one.
__________________
2002 SS Convertible #2742 - UMI SFC, C5 Brakes
ROCNDAV is offline   Reply With Quote
Old 10-26-2009, 02:37 PM   #3
Trader Rating: 9
I have one on my 00 T/A. Don't know about the rest of the models. And usually they put them on there for a reason.
niceguyyy01 is offline   Reply With Quote
Old 10-26-2009, 02:57 PM   #4
Trader Rating: 79
I've read of some people take their coolers off. They refer to them as "heaters" rather than coolers, because it runs the hot engine coolant around the PS fluid.
__________________
Old 10-26-2009, 03:11 PM   #5
DAS1998's Avatar
Trader Rating: 1
make sure you check your steering shaft.. i have replaced a ton of them for noise and frozen u-joints. might not be your problem but just thought i would pass that along.
Mike
DAS1998 is offline   Reply With Quote
Old 10-26-2009, 04:35 PM   #6
kmgsix08's Avatar
Trader Rating: 12
Quote:
Interesting. Does PS fluid perform better when its hot or something? Maybe the guy that tried to explain it to me had it backwards. He said that it cooled the PS fluid to prevent damage to the gear box. I bought one already, I'm just trying to decide whether or not I want to use it.
__________________
Old 10-26-2009, 04:39 PM   #7
Trader Rating: 0
I put an 01 rack on my 93 V6 car. So, yes. Put it on and be finished with it. Just put you new tie rod ends on and get an alignment when you are done.
__________________
Slow and Junkie 94 Z
5 HP Briggs. Stroked. Sprayed.
whitehooptie is offline   Reply With Quote
Old 10-26-2009, 05:05 PM   #8
kmgsix08's Avatar
Trader Rating: 12
Quote:
Thanks man. I have the new tie rod ends. I think I should probably get a new bushing for it since it's a convenient time. Is it just called a Rack Bushing or what?
Thanks for the help guys
__________________
Old 10-26-2009, 05:31 PM   #9
Trader Rating: 0
You talking about the steering shaft? LT1 cars have a replaceable bushing, but I don't think LS1 cars do....
__________________
Old 10-26-2009, 05:33 PM   #10
Trader Rating: 0
Oh, and I would at least "eyeball align" it if it is too bad. Just measure the distance between the outsides of both tires the best you can so they are as even as possible. I didn't do that once when I changed the rack on my v6 car and it chewed through a tire in 2 days.
__________________
Old 10-26-2009, 08:57 PM   #11
neutron82's Avatar
Trader Rating: 9
grab an extra rack bolt from the dealer... one of the bolts is going to hit the bottom of the oil pan when you try to take it out... easiest way to do it is cut the head of that bolt off so it will just fall out and install the new bolt from the bottom and use some red thread locker to hold the nut on... the other bolt will come out fine... i did mine this way when i did my rack... if you don't want to do it this way you're gonna have to loosen the mounts and jack the motor up to get it out... mine has been fine this way and that bolt will not come loose unless i ever have to take it out again... i wouldn't run the factory p.s cooler the way they are set up on our cars but if you want to go with an aftermarket one it wouldn't hurt, but i don't think it's necessary for a daily driver... the factory ones will get the fluid hot with coolant and they always end up mixing coolant and p.s fluid and creating a big mess and problems
neutron82 is offline   Reply With Quote
Old 10-27-2009, 10:28 AM   #12
DSIM's Avatar
Trader Rating: 1
Send a message via MSN to DSIM
Quote:
Mike
^^^What this guy said.
When I worked for a GMC dealership one of the recalls for the Yukon/Tahoe was the steering shaft, the u-joint in there would go bad and make a popping sound. Easy way to test is to shut the car down and move the steering wheel... if you hear the pop then it is most likely the knuckle (u-joint) in the shaft going bad.
__________________
I dont have anything worth putting here
DSIM is offline   Reply With Quote
Old 10-27-2009, 10:34 AM   #13
cookba's Avatar
Trader Rating: 4
Location: Ocala, Fl = home Seoul, South Korea = stationed
my PS cooler leaked the entire reservoir into my radiator. DON'T PUT THE COOLER ON!
__________________
2002 Camaro Z28 A4 - UMI sfc phr lca ta, BMR stb, Strano sway bars and springs, Koni 4/4 shocks, p&p tb, Kooks headers, GMMG catback, built up 4L60E.
In progress: 228/230 114LSA Cam, Tony Mamo ported AFR 205's and 92mm FAST, NW 92mm TB, fabbed MWC 9" w/ 3:70's, FLT 4L60E, FTI 3600 stall, PST 3.5" DS, UMI K-Member.
cookba is offline   Reply With Quote
Old 10-27-2009, 10:58 AM   #14
kmgsix08's Avatar
Trader Rating: 12
Thanks for yall's input. I definitely wont be putting the cooler on now.
__________________
Old 10-30-2009, 11:24 AM   #15
Trader Rating: 0
Send a message via AIM to The Darkness
Ive got a related question, one of the bushings on my 00 T/A WS6 is shot, can i just replace that bushing or should i just go ahead and get spendy and buy a new tie rod for that side? What do i have to replace?
The Darkness is offline   Reply With Quote
Tags
01, 02, 2000, bad, bushings, camaro, changing, cooler, end, power, rack, replacing, rod, shaft, ss, steering, tie
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
LS1TECH - Archive - Top
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
Advertising - Terms of Service - Privacy Policy - JOBS
