Click here to visit LS1Tech
Click here to visit Performance Trucks
Click here to visit Mod Motor Tech
Click here to visit Modern Hemi
LS1Tech Wiki
LS1TECH
Go Back   LS1TECH > LS1-LS2-LS3-LS6-LS7 PERFORMANCE > Tools & Fabrication
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into LS1Tech.com, click logo to login
Old 08-03-2009, 12:06 AM   #1
Trader Rating: 7
Default Hardwood Floor nail gun help
I am thinking about installing hardwood floors in my house and was wondering if it would be worth while to rent one from home depot or just buy one from harbor freight? It would be 3/4" solid prefinished wood.
Thanks
__________________
mrhzk35404 is offline   Reply With Quote
Old 08-03-2009, 12:52 AM   #2
Trader Rating: 25
Default Buy It
I bought the harbor freight one when it was on sale so I could do the job at my leisure. It actually works better than the beat up one I rented for the previous job.
gto69judge is offline   Reply With Quote
Old 08-03-2009, 08:57 PM   #3
Trader Rating: 7
Did you use the nails or staples from harbor freight or did you buy them somewhere else? Did you have any issues with it jamming up?
__________________
Old 08-03-2009, 09:09 PM   #4
Trader Rating: 0
http://www.ls1tech.com/forums/album.php?albumid=585
I helped you out and found a Power Nailer rental near your location on your name though it wouldnt copy the link so youll have to do it again yourself. Best guns there are and their power cleats are much better than staples
http://www.powernail.com/ and http://www.powernail.com/rentals/index.htm
lt1badbird is offline   Reply With Quote
Old 08-03-2009, 09:36 PM   #5
Moderator
2002 Chevrolet Camaro
jimmyblue's Avatar
Trader Rating: 11
I did my tongue and groove front porch by drill and screw
(R1 bit stainless screws). Tedious, but that shit ain't pulling
out, nohow.
__________________
2002 SS convertible
SLP Blackwing lid, 85mm MAF, 85mm Professional Products intake & TB, SLP CME, Jet-Hot LTs/ORY, McCord cutout, Fuddle 3500/2.0, GM truck pan, '98 flexplate, 3.42s, T-2R, MAC cover, welded tubes, Hotchkiss PHR, springs; BMR bolt-in LCA brackets, K-member; UMI TA, boxed stock 1LE LCAs, SLP Bilstein / Gabriel air shocks (F/R); Strano 35/22 sway bars, 224/224 116 cam, 160F 'stat, HPTuners 12.6@112MPH
jimmyblue is offline   Reply With Quote
Old 08-03-2009, 09:54 PM   #6
Trader Rating: 0
understandable for a small outside porch that will see the elements....inside, no
Old 08-03-2009, 10:24 PM   #7
1999 Chevrolet Camaro
SS99LS1's Avatar
Trader Rating: 20
Send a message via AIM to SS99LS1
i just finished putting 5/8 bamboo in my house today, i just rented a nailer from home depot for 35 bucks a day took me 3 days at my own pace i wouldnt buy one if this is the only time your going to use it.
__________________
03 c5 electron blue z51 m6. stock for now
99 SS black A4 #0193 t-top
mti clear lid,k+n filter, slp maf,smooth bellows, pacesetter coated lt's, tsp catted "y",hooker cat back, 2800 yank,[313rwhp/317rwtq sold
SS99LS1 is offline   Reply With Quote
Old 08-03-2009, 11:18 PM   #8
Trader Rating: 7
Thanks for the help. It looks like it would be much cheaper to rent a better one then buy a cheap HF POS.
__________________
Old 08-16-2009, 06:30 PM   #9
Trader Rating: 0
check with the local lumber yard. Mine lets you use the nailer if you buy the flooring from them
__________________
04' Black/Red GTO M6: Comp 228/230, partoit stage 2 heads and ASP pulley, Kooks 1 7/8" w/cats, SLP 160* thermo, NGK plugs, Modified Speed Intake, SLP rear sway bar, sub frame bushings, Nitto DR's, drag bags, LS7 clutch, 3.91's
Dyno results: 360rwhp 335rwtq (mustang dyno)
Best 1/4 mile: 13.2@106 with bad conditions
2007 2500 HD Excab Z71 Duramax/ allison PPE 90hp tune, MBRP turbo back, PPE air box mod (work truck)
04LS1GTO is offline   Reply With Quote
Tags
buy, depot, floor, flooring, floors, gun, guns, hardwood, home, installing, nail, patriot, rental, wood, wwwpowernailcom
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
LS1TECH - Archive - Top
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
Advertising - Terms of Service - Privacy Policy - JOBS
