Click here to visit LS1Tech
Click here to visit Performance Trucks
Click here to visit Mod Motor Tech
Click here to visit Modern Hemi
LS1Tech Wiki
LS1TECH
Go Back   LS1TECH > LS1-LS2-LS3-LS6-LS7 PERFORMANCE > Tools & Fabrication
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into LS1Tech.com, click logo to login
Old 10-28-2009, 09:11 PM   #1
1998 Chevrolet Camaro
greatskiiiier's Avatar
Trader Rating: 9
Send a message via AIM to greatskiiiier
Default air compressor or welder?
i have some money to spend (~200) and ive been saying my next big investment will be a welder or an air compressor
now which one should i get???
i can get a new 90amp flux/ gas welder for around 200 (should be good for up to 1/4" on 2-3 passes)
OR an air compressor capable of 5cfm for around 180 and tell my parents and gf to get me air tools for the holidays
which one would better suite me for the time being???
__________________
1998 Z28 M6... 14.051 Slip
1975 Kawasaki F7- IN PROGRESS
1994 Toyota Pickup 22re M5
1997 Buick LeSabre- PARTING OUT
Quote:
Originally Posted by ARCTIC '00 View Post
greatskiiiier
greatskiiiier is offline   Reply With Quote
Old 10-28-2009, 11:33 PM   #2
KurtRardin's Avatar
Trader Rating: 11
Ouch... $200 isnt a great budget for either of those items honestly. What are the name brands you're looking at? The only 90amp welder I know of for less than $200 is a Chicago, and its only a flux wire welder, not mig.
When it comes to air compressors, forget all about PSI. If you're talking about 110v or 220v compressors they'll all make the PSI you'll use. Its CFM that you have to shop. 5cfm at 90psi isnt that great, as in it will be close to the threshold of making average air tools barely work with the compressor running constantly. 12cfm at 90psi, on the other hand could run a sandblaster.
It all boils down to what you want to use it for. If you plan on not running any air tools other than stuff to air up your tires and maybe an air wrench for split seconds, then you'll be okay. If you've got plans for an air compressor for your shop then you need to keep shopping... something 220v that turns at a low RPM and puts out a high Cubic Feet per Minute.
Both the welder and compressor could be lifetime investments...
__________________
98 Z28 M6 HardTop
HotCam, SLP RamAir, Clear Lid, New Era P&P, LS6 Intake, LTs, 4" PaceSetter ORY, Hooker, 4.10, Monster III, Tick Master Install Howto, HPTuners. Soon to be S60!!!
KurtRardin is offline   Reply With Quote
Old 10-28-2009, 11:38 PM   #3
KurtRardin's Avatar
Trader Rating: 11
FWIW, I've got about $400 in a Rol-Air 80 gallon compressor off govdeals. Thats including the cost of another 5hp motor and the electrician hooking it up. And about ~300 in a 110v lincoln 135amp mig welder from home depot (closeout).
Only buy the truly smokin deals!
__________________
98 Z28 M6 HardTop
Old 10-29-2009, 06:23 PM   #4
MikeGyver's Avatar
Trader Rating: 3
Almost everything that you use a compressor for can by done manually, the only way to weld without a welder is gas welding (oxy-acetylene). Anybody who learns to gas weld first is much ahead of the curve as far as skills go. You also have the ability to cut steel with oxy-acetylene. For $200 you can get a nice, used torch outfit. For the same money, a compressor or welder will be a piece of poop, even used.
__________________
Install pictures here.
2000 2500 HD
408 Whipplecharged
Intercooled
MikeGyver is online now   Reply With Quote
Old 10-29-2009, 08:23 PM   #5
KurtRardin's Avatar
Trader Rating: 11
Good point on the torch outfit. A cutting torch is a great excuse to go that route The ol' heat wrench has come in handy a time or too for me, lol. I've never tried to weld with one, but its definitely a tried and true method.
To the OP, you can get a haynes manual (same dudes that makes car books) on welding that spells out all the different types of welding and it gives good techniques on them too.
On the other hand though, a nice little mig setup sure does make you feel like pro in about 30 minutes...
__________________
98 Z28 M6 HardTop
Old 10-30-2009, 07:34 AM   #6
waltsfastz's Avatar
Trader Rating: 4
Send a message via Yahoo to waltsfastz
Dont ever buy a cheap weldler, You WILL regret it.
Buy an air compressor. You will use it every day you work on your car. a welder you may not use it ever.
A compressor is a must
__________________
Z-28 Workin on it,th350 wbrake, Solid roller 383, spray, 9 incher,cage
02 Z-28 vert, Flowmaster Catback, Pacesetter LTs,ORY,Edge Convertor, Lid,Spray, 12.32@107.93,1.622 60 ft,now spray and tr224.
waltsfastz is offline   Reply With Quote
Old 10-30-2009, 10:20 AM   #7
Trader Rating: 0
i say go with compressor. if 200 dollar budget look on craigslist as i have seen some nice home setups for that price. i socred a 7.5hp one of ebay years ago for very reasonable. infact still using it. but that is probaably overkill for home shop.
you will need an air compressor if you get a welder. chances are you will run grinders cut off wheels etc with air.
__________________
Quote:
Originally Posted by Phil99vette View Post
Your 100% right its an expensive muffler, how many mufflers have you seen add 1000rwhp?
bgblockelcamino is offline   Reply With Quote
Old 10-30-2009, 10:27 AM   #8
Trader Rating: 1
ouch $200 is not much of a budget... maybe a nice tap and die set? (worth every penny IMO)
Andrew R is offline   Reply With Quote
Old 10-30-2009, 10:29 AM   #9
Cliff's Avatar
Trader Rating: 18
Save your money until you have enough for a good quality item. Nothing worse then buying a cheap product that is unable to do the job. Very frustrating when you need a good quality, strong weld and when your life depends on the welding. Or a compressor that wont run a air tool more then 3 seconds and the you wait 1 minute for the unit to catch up before it will run another 3 seconds. Been there and it's a real pain!!!!!!!!!!!!!
__________________
2000 WS6:427 Solid roller LSX, ETP 6 bolt heads, MWC fab 9, th400 with a big nasty cam for nitrous.
2000 WS6 Formula ( show car.........)
Cliff is online now   Reply With Quote
Old 11-14-2009, 10:48 PM   #10
Trader Rating: 4
Quote:
yep chicago makes a 90 amp and I have one its a piece of crap save some more money and buy a real welder or air compressor
I like my compressor set up 2 150psi portercable pancake's conected together and atached to a 30 gal tank(my dad downsized his carpentry biz) its ghetto but it works and its red so its gotta be high performance
camaroz28383 is offline   Reply With Quote
Old 11-15-2009, 06:24 AM   #11
eseibel67's Avatar
Trader Rating: 5
Send a message via MSN to eseibel67
I play around in the garage after work every day. I could not live without compressed air. It's so versatile.
A welder would be nice, but that's more of a luxury item.
__________________
01 WS6 M6
eseibel67 is online now   Reply With Quote
Old 11-15-2009, 12:35 PM   #12
1999 Subaru Legacy
My Garage
subarubill96's Avatar
Trader Rating: 5
Quote:
+1 i learned this way and it really did put me ahead of the curve when it came time to jump up to a buzz box. plus the cutting feature is great for us guys without $1500 or so to blow on a plasma cutter. awesome suggestion
__________________
99 Black Trans Am- sleek beak freak
99 Subaru Legacy- under going heart surgery
"i'm still trying to figure out how this thread went from welfare abuse, to racial wars, to homosexual proposals. ls1tech has gone down hill... LOL "
subarubill96 is offline   Reply With Quote
Old 11-15-2009, 10:28 PM   #13
Trader Rating: 9
i got the welder- 140amp 110V clarke mig/fluxcore... i can weld decent with a mig as is and figured anything i could do with air i can do manually/ use electric... as stated, you can wrench without air, you cant fuse metal without a welder
__________________
greatskiiiier
Old 11-15-2009, 10:36 PM   #14
shtnfrds's Avatar
Trader Rating: 1
every time i open the garage door my compresser is used for one thing or another. i havent used my welder in.. well a really really long time.
__________________
2000 Camaro Z28NBM, A4, 2.73's, Coated Pacesetter LT's, TSP Rumbler-X TD, Dynomax, Lid, Drop-in K&N, descreend MAF...
170,xxx miles!!
2004 Silverado 2500HD, True Dual Flowmaster original 40's, Sport King AT 285/75/16's, Diablo Tuned.
shtnfrds is offline   Reply With Quote
Old 11-17-2009, 09:15 AM   #15
Trader Rating: 0
You will use the air compressor more. If you get a welder gas a gas mig.
nicholas1752 is offline   Reply With Quote
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
LS1TECH - Archive - Top
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
Advertising - Terms of Service - Privacy Policy - JOBS
