Click here to visit LS1Tech
Click here to visit Performance Trucks
Click here to visit Mod Motor Tech
Click here to visit Modern Hemi
LS1Tech Wiki
LS1TECH
Go Back   LS1TECH > LS1-LS2-LS3-LS6-LS7 PERFORMANCE > Tools & Fabrication
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into LS1Tech.com, click logo to login
Old 03-05-2006, 02:23 PM   #41
sickss228's Avatar
Trader Rating: 26
Sent you a PM Hawk
__________________
2001 SS M6 CARTEK 4x Heads&Cam, Six Speeds Inc. Trans, CARTEK Clutch, Moser 12bolt (spool & 4.56's), Stealth torque arm, Tuned by CARTEK 10.xx@1xx.67 1.56 60'
2005 Chevy 2500HD Duramax Diesel crew cab, MBRP 4" turbo back, Edge Juice w/ attitude, kennedy boost stick, 285/75-16 BFG AT's
USMC infantry (02-06) SEMPER FI
sickss228 is offline   Reply With Quote
Old 03-07-2006, 01:42 AM   #42
618HAWK's Avatar
Trader Rating: 352
Send a message via AIM to 618HAWK
All pm,s replyed and tracking #s sent. Thanks
__________________
2001 Artic White M6 WS6 Procharged D1SC 635HP 576TQ @ 10 psi
Diamond pistons, Akerly&Childs rings, scatrods, Clevite rod and main bearings, Full ARP rod and head studs, Meilling hv OP, LS7 lifter & trays, Ls2 chain, Yella Terra roller rockers, Comp rods
AFR 225s, Cometics,Comp cam 232/240 595/608 115
Racetronics double pumper, SLP subframes, loop, Tq arm, UMI LCA & PHR, AutoMeter Boost FP, water, air temp, DynoJet wideband. T56 Lvl 4 build, Textraila Z-grip.
02 FireHawk #618
00 SS
618HAWK is offline   Reply With Quote
Old 03-08-2006, 06:17 PM   #43
bshell's Avatar
Trader Rating: 14
Just received my tool today. Excellent product, very professional looking! All of my co-workers (R&D company) can't believe this tool wasn't special ordered from one of the major tool manufacturers! Thanks 618HAWK!
__________________
99 Hawk T/A NBM
Proud to be a part of VA Speed
www.virginiaspeed.com
bshell is offline   Reply With Quote
Old 03-08-2006, 06:41 PM   #44
MattDZ28's Avatar
Trader Rating: 1
PM me your info as well. I want one.
__________________
02 T/A bolt-ons
MattDZ28 is offline   Reply With Quote
Old 03-10-2006, 09:13 PM   #45
NassyVette's Avatar
Trader Rating: 22
618Hawk is a pleasure to deal with, shipped the item out fast and it looks great!
__________________
98' C5
98' Z28
NassyVette is offline   Reply With Quote
Old 03-10-2006, 11:10 PM   #46
618HAWK's Avatar
Trader Rating: 352
Thanks...........NassyVette , bshell.
__________________
02 FireHawk #618
00 SS
Old 03-10-2006, 11:19 PM   #47
sickss228's Avatar
Trader Rating: 26
Hey Hawk used the tool today, very nice piece of work
__________________
Old 03-10-2006, 11:27 PM   #48
618HAWK's Avatar
Trader Rating: 352
Quote:
Well Thank You.........Glad to have helped
__________________
02 FireHawk #618
00 SS
Old 03-10-2006, 11:43 PM   #49
Silverback's Avatar
Trader Rating: 0
Excuse me if I’m missing the point, and 618HAWK, please don’t feel that I’m taking anything away from your ingenuity, BUT (the big “but”):
I’m not sure that I really get it. Yea, it lets you draw the damper onto the crank without putting as much of a load on the crank threads, which is a good thing, but all-thread is not a great way to do it, it’s roughly the strength of grade 0 or at most 2 hardware but the threads are usually cut, not rolled so they’re not even that strong, and not intended for this kind of stress. I wouldn’t be at all surprised if after a bunch of uses that rod doesn’t end up munching a set of crank threads anyway from just not having the strength to last in that kind of application (real world, you’ll probably get lucky and you’ll just munch up the threads on the all thread and nut on the other end).
Secondly, all this noise about it needing a bearing… well, I guess in a nice, perfect world maybe something like a sealed thrust bearing would be cleaner then the alternative, but 2 washers with some grease with an extreme pressure additive in it would be plenty (normal chassis or bearing grease would actually be fine, something like an assembly lube with moly would be ideal).
While on that subject, in most metals it takes 3 (steel…) to 5(aluminum) threads engagement to get the full holding strength of a set of threads, IF you were going to use a bolt to draw the balancer on, if you coated the threads with an appropriate grease and made sure that it was long enough that you got reasonable thread engagement you will actually, real world have a more reliable way of performing the task (of course, this tool still has the advantage that when it does fail it will most likely fail in a way that will not hurt the threads in the crank where using a longer bolt will if something fails)
Finally, Hawk, it looks like you’re welding some normal zinc plated hardware… I hope that you’re stripping that zinc with something before you do the welding since the gasses produced when welding anything zinc plated will get you quite sick with heavy metal poisoning.
__________________
Mark
aka: Silverback, WS6 TA, JYDog, 83 Crossfire TA, mpikas, mmp...
Silverback is offline   Reply With Quote
Old 04-20-2006, 11:16 PM   #50
1QWIKBIRD's Avatar
Trader Rating: 13
Thumbs up
I'm not a mechanical engineer so I can't speak to the thread engagement theory and I do know that thread-all is not known for its strength, BUT (there is always a but) I recently bought one of these tools from 618HAWK and it worked flawlessly. I threaded the long bolt in to the crank until it bottomed, then backed it out 1 full turn with a light coat of 30w motor oil on the threads, and some liberal greasing (supplied with the tool) to both faces of the washer. A coat of the same 30w oil on the crank snout and the new timing cover seal and with out any herculean efforts, binding, gouging, 4' long pipes, BFH (big F$&*ing hammers), stripped threads (in the crank or on the tool), busted knuckles or any other surprises the balancer was installed on the crank.
The tool flat out works and for the price you would be hard pressed to recreate the tool yourself without having 2 extra feet of of metric thread-all lying around, 11 extra specialty washers and a tube of extreme pressure lubricant. If you install a balancer and damage crank threads because you didn't use this tool, you almost deserve it (almost).
This tool is sweet piece and the price makes it even sweeter, but the fact that it works flawlessly, makes it a must have tool for anyone working on LSx based motors...Not knocking the kent moore tool or the snap tool, but I'm sure they are way more expensive....And I'm not taking a shot at Silverback either, but sometimes theory gives way to real world experience.
I'm a do it you self guy and this tool will be in my roll-away for a long time. Hell I could probably rent it out and make the purchase price back...hahahah.....(I wouldn't do that!)
Chris Ciatteo
__________________
Chris
99 Firebird (The driver)
70 Nova (The toy)
97 2500 Ext. Cab 4x4 LWB CTD (The Earthmover)
1QWIKBIRD is offline   Reply With Quote
Old 07-03-2006, 03:57 PM   #51
chad2775's Avatar
Trader Rating: 1
Just used the tool and all I can say is its perfect!!, Made the dreaded crank pulley install one of the easiest parts of the cam swap!! Money WELL spent!!
__________________
2000 Black WS6 M6- slp lid-CAI,- P/P TB, TB bypass, STB, manual fan ovrd, raptor shift light, TR 224/224 112, LT's w/cats, Pro-Flo twister
chad2775 is offline   Reply With Quote
Old 07-03-2006, 07:43 PM   #52
8 Second Cyber Gray Mod
Navy David SS's Avatar
Trader Rating: 12
Need to clean out your PM box. PayPal sent.
thanks
David
__________________
1998 SS NBM, Build #114, A3
My SS
My SS Site on fquick.com
Sponsored by Excessive AutoSports, Sioux Falls, SD
Navy David SS is offline   Reply With Quote
Old 07-04-2006, 10:22 AM   #53
Trader Rating: 0
PM sent
motopsychoz is offline   Reply With Quote
Old 07-06-2006, 12:37 PM   #54
HUGGER ORANGE SS's Avatar
Trader Rating: 1
I still think Chris needs to Clean in Finger Nails.... Kidding.. I know your a working Man..
__________________
A.i.R. American Intense Racing
www.myspace.com/airacing
My car: 99' HUGGER ORANGE CAMARO SS
742RWHP 722RWTQ Forged 347 & D-1SC
New Setup in Progress.
HUGGER ORANGE SS is offline   Reply With Quote
Old 07-07-2006, 11:20 AM   #55
Trader Rating: 0
i need this pm me
corwin123 is offline   Reply With Quote
Old 07-07-2006, 11:57 AM   #56
618HAWK's Avatar
Trader Rating: 352
Quote:
Originally Posted by corwin123
i need this pm me
PM sent
__________________
02 FireHawk #618
00 SS
Old 07-09-2006, 02:44 PM   #57
jegten's Avatar
Trader Rating: 10
pm sent
__________________
00DodgeRam1500Sport4x4 XCabBlck
04GTO IBM/blue/M12/3.46
show-MPD Scorpio hood,06-rear/tails/doorlock button,JHP gauges,Monaro ftrest,Pioneer System,rt530 mod,Grafxwerks.ready-forged ls3 418, WCCH LS6 stg 4 63cc, Ported 92mm LS6 intake, NW 92mm TB, RollMaster, Lucas42lb, coated Kooks SS/catless,JBAcatback/bluewires,OTRCAI,NGK TR6,GMM R/S/TSS-euroknob,05 breaks/BaerSS lines, blue AMW cc,SLP-skid plate/160 tstat/udp, Monster 6, IngallsETD,HPTuners/PLX,tuned by me.FOR SALE-modded LS1 long block
jegten is offline   Reply With Quote
Old 07-09-2006, 03:47 PM   #58
618HAWK's Avatar
Trader Rating: 352
Quote:
Originally Posted by jegten
pm sent
Pm returned Thanks
__________________
02 FireHawk #618
00 SS
Old 07-20-2006, 04:05 PM   #59
Moderator
davered00ss's Avatar
Trader Rating: 4
TTT for ya.
__________________
davered00ss is offline   Reply With Quote
Old 07-21-2006, 11:45 AM   #60
Trader Rating: 1
Thanks to Chris for his assistance in completing the transaction and for promptly shipping the tool. It appears to be engineered thoughtfully and the finish is impressive. Having such items readily available saves time and money when the projects are stacking up.
Thanks again,
cnorton
cnorton is offline   Reply With Quote
Tags
2001, balancer, crank, dampner, hawk, hawks, instal, install, installer, locking, ls1, ls3, ls7, pulley, snout, tool, washer, wwwairacingcom
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
LS1TECH - Archive - Top
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
Advertising - Terms of Service - Privacy Policy - JOBS
