Click here to visit LS1Tech
Click here to visit Performance Trucks
Click here to visit Mod Motor Tech
Click here to visit Modern Hemi
LS1Tech Wiki
LS1TECH
Go Back   LS1TECH > LS1-LS2-LS3-LS6-LS7 PERFORMANCE > Tools & Fabrication
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into LS1Tech.com, click logo to login
Old 10-08-2005, 02:42 PM   #1
618HAWK's Avatar
Trader Rating: 352
Send a message via AIM to 618HAWK
Default New Crank dampaner installation tool... Pics
Update--------05-07-2007
Here it is, the tool for crank dampaner installation, no more fighting with it
or taking a chance of damaged crank threads. I have recently started to add a thrust bearing to the tool. There may be other threads-pictures floating around, with an old style 2 washer design. If so, sorry, this is the new version that I am putting together now.
As well, there may be posts within this thread about bearings and other ideas. So it may be a bit confusing.
Well the tool has been doing great; have not had any complaints as of yet..... as you can tell by my trader rating. And yes some of that is other transactions as well.
Cost of tool= $45.00 shipped USPS Pri Mail with dlvr-conf-trking#.
Please send me a PM or Email if needed caspnes@comcast.net
Update........ I am currently out of tools.
To make matters worse I had to travel out of the country for approx 4 weeks if I wanted to keep my job.
I plan on having another batch ready to go around mid-end of July. Sorry for any problems this may have caused.
Thanks and sorry................Chris
618HAWK is offline   Reply With Quote
Old 10-09-2005, 04:04 AM   #2
Trader Rating: 2
nice, too bad ur not close to me...I need that tomorrow
Screamin_Z is offline   Reply With Quote
Old 10-10-2005, 02:03 AM   #3
Trader Rating: 0
How much?
viper punisher is offline   Reply With Quote
Old 10-10-2005, 11:08 PM   #4
Trader Rating: 0
Send a message via Yahoo to StretchNutz
beautiful! (both idea and execution)
StretchNutz is offline   Reply With Quote
Old 10-13-2005, 10:10 PM   #5
Trader Rating: 2
got mine in today will try it out and let you know as soon as this Saturday provided my other parts show up.
__________________
1999 Trans Am - MTI lid, Holley power shot air filter, free ram air,smooth bellows,ASP underdrive pulley,160* t-stat, pacesetter headers, TSP Y-pipe,tb bypass, self ported throttle body, 85mm MAF, MSD wires, AC Delco iridiums, Bilsteins, Eibach pro-kit springs, Hooker cat-back exhaust, A4, 3.23's, comp cam 222/224 566/568 112 LSA, comp 918 valve springs, thunder racing pushrods
ASE master certified plus L1 certified
1999 chevy 1500 5.3 ported tb, hooker aerochamber,e-fans
Cody Brooks is offline   Reply With Quote
Old 10-14-2005, 05:31 PM   #6
Trader Rating: 6
For those that are using this or plan on using this.... I HIGHLY recommend that you find some type of thrust bearing to use in conjuction with this setup. They can be had very cheaply at most local bearing supply places.
Also what type of hardware are you using to make these? looks like stainless?
__________________
http://usera.imagecave.com/Jrichter212/sigblur.jpg
2000 Firehawk #64
2003 Yamaha R6
2006 Ford F-250 Powerstroke
JRick212 is offline   Reply With Quote
Old 10-15-2005, 02:04 PM   #7
Trader Rating: 2
used it today great tool. i did have 1 rcommendation which i sent to 618 hawk which i'm sure he'll take care of. you guys that want to put on a pulley this is the way to go.
__________________
Old 10-15-2005, 08:38 PM   #8
618HAWK's Avatar
Trader Rating: 352
Cody
Thanks for the good info and feedback. I will defiantly take your suggestions in to the design.
__________________
2001 Artic White M6 WS6 Procharged D1SC 635HP 576TQ @ 10 psi
Diamond pistons, Akerly&Childs rings, scatrods, Clevite rod and main bearings, Full ARP rod and head studs, Meilling hv OP, LS7 lifter & trays, Ls2 chain, Yella Terra roller rockers, Comp rods
AFR 225s, Cometics,Comp cam 232/240 595/608 115
Racetronics double pumper, SLP subframes, loop, Tq arm, UMI LCA & PHR, AutoMeter Boost FP, water, air temp, DynoJet wideband. T56 Lvl 4 build, Textraila Z-grip.
02 FireHawk #618
00 SS
Old 10-15-2005, 08:47 PM   #9
618HAWK's Avatar
Trader Rating: 352
Yes thinking of some type of bearing or a way to prevent gauling. Even though, when a dampener is installed with just the bolt there is no thrust bearing incorporated in that scenario.
As for material it is not stainless just cleaned up nice after welding. Pictures were taken prior to final finish.
__________________
02 FireHawk #618
00 SS
Old 10-16-2005, 12:20 PM   #10
Trader Rating: 6
Yes I do not use the bolt method and I agree that your tool is much better than the bolt method.
What grade of hardware is it though? I see no markings on the head of the bolt? 8.8, 9.8, 10.9 etc?
__________________
2000 Firehawk #64
2003 Yamaha R6
Old 10-16-2005, 01:31 PM   #11
Trader Rating: 2
its accually not a bolt but a piece of all thread with a nut welded to the end. as you can tell he uses tig welds and they are very clean.
__________________
Old 10-16-2005, 06:23 PM   #12
Trader Rating: 6
wow I guess so
__________________
2000 Firehawk #64
2003 Yamaha R6
Old 10-16-2005, 08:44 PM   #13
Trader Rating: 1
I just used this tool over the weekend on my gto. Personally, I thought it worked very well. Since I had the radiator out, it was a breeze. For $25, it is well worth it. A few quick notes: after I cranked the pulley down as far as I could, the inner bolt loosened very easily, the threads stayed 100% in order, and the main stud loosened very easily. I had the pulley almost fully on, except for about an eighth of an inch. I'm going to see if it works with the radiator in tomorrow night.
qsgto is offline   Reply With Quote
Old 10-16-2005, 11:59 PM   #14
Trader Rating: 2
i used the one I got with the radiator in the car the only thing I had to move was the tranny cooler lines which I had to move so I could get my impact in to break the bolt loose. I put the asp pulley on the snout of the crank and then started this tool into the crank and ran it down by hand until I couldn't turn it anymore by hand. I then ran the pusher down by hand until it made contact I then held the out nut with a 15/16 and turned the pusher with another 15/16. I did this at first with the pusher as it comes no lube on it or thrust bearing which meant the pulley got on a little ways before it got difficult to turn. I removed the tool and added 90w-140 to the end of the pusher and put a washer on it and put some more 90w-140 on the outside of it to form a makeshift bearing. After doing that the pusher pushed the pulley completely flush without any effort at all. I then threaded the crank bolt in and tightened it.
very good tool. my recommendation which I said I told 618 hawk about earlier is to include the extra washer and some sort of grease packet or atleast give a couple good recommend greases or oils to use to lubricate and prevent binding. I also told him that he could go ahead and shorten the overall length of the threaded tool up to 1/4 of an inch to help clear the radiator and cooling fans but works fine as is.
__________________
Old 11-15-2005, 07:41 PM   #15
Trader Rating: 5
PM'd you about ordering one of these
wanklin is offline   Reply With Quote
Old 12-07-2005, 08:51 PM   #16
Trader Rating: 0
Ordered mine today!
99C5Coupe is offline   Reply With Quote
Old 12-07-2005, 10:34 PM   #17
618HAWK's Avatar
Trader Rating: 352
Quote:
Originally Posted by 99C5Coupe
Ordered mine today!
Thanks will get it out in the morning..........
__________________
02 FireHawk #618
00 SS
Old 12-08-2005, 02:53 PM   #18
HUGGER ORANGE SS's Avatar
Trader Rating: 1
Gentlemen..
Chris 618Hawk does amazing work.. If you need this tool, You'll be getting a quality piece...
Clint
__________________
A.i.R. American Intense Racing
www.myspace.com/airacing
My car: 99' HUGGER ORANGE CAMARO SS
742RWHP 722RWTQ Forged 347 & D-1SC
New Setup in Progress.
HUGGER ORANGE SS is offline   Reply With Quote
Old 12-12-2005, 05:45 PM   #19
Trader Rating: 0
Mine arrived today. This should make the pulley install easy and save the crank threads. I allways like quality tools, thanks Chris!
Rex
Old 12-13-2005, 12:29 AM   #20
618HAWK's Avatar
Trader Rating: 352
Rex
Thanks Rex
Glad to help
__________________
02 FireHawk #618
00 SS
Tags
2001, balancer, crank, dampner, hawk, hawks, instal, install, installer, locking, ls1, ls3, ls7, pulley, snout, tool, washer, wwwairacingcom
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
LS1TECH - Archive - Top
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
Advertising - Terms of Service - Privacy Policy - JOBS
