FS: 1999 Pontiac Formula
----------ENGINE MODIFICATIONS----------
SLP LS1 short throw shifter with TNA Short stick
Whisper High flow carbon fiber intake lid with K&N High flow air filter
GMParts 85mm ZO6 Mass Air Flow
HyperTech 160 low-temp thermostat
F.A.S.T Painted 90mm intake plenum with F.A.S.T Fuel Rails
Nick Williams 90mm Throttle Body
GM Parts 28.8lb injectors
Holley FlowTech Ceramic coated full length headers, CUSTOM Off-road Y-pipe, McCord Power Plate electric cutout, Hooker CatBack exhaust, DynoMax Ultraflow muffler
MODIFIED FRA, deleted EGR, deleted AIR pump, Smooth bellow
MSD 8.5mm Super conductor spark plug wire set with NGK TR55 spark plugs
TEA Stage II 5.3L ported/polished cylinder heads
Thunder Racing chromoly pushrods
Thunder Racing Custom Grind Camshaft TR232/237 .594/.604 112 lsa
March Performance Harmonic dampener crank pulley
McLeod REVLOK Single disc clutch with McLeod Adjustable master cylinder
Moser 12-bolt, 33 spline with 4.11 gear
3.5" Aluminum drive shaft with 1350 race yoke
Billet Prototype - Catch can
HP Tuning (street performance tune)
----------SUSPENSION----------
Spohn 4140 Solid Rear Sway Bar with poly bushings
UMI Adjustable Tunnel Brace Mounted Torque Arm
Freedom Design Strut tower brace
Eibach Pro-Kit (1.4") front (rears included)
BMR Lowering spring (1.0") rear
UMI Adjustable panhard rod
Spohn Weld-in subframe connectors
BMR Rear Swaybar mount kit
UMI Weld-in relocation brackets
----------VISUAL APPEARENCE----------
HP EVO 18" wheels with Sumitomo HTRZII tires
SLP Ram Air H.O. fiberglass hood
LS1 side marker laser cut decals
I also have some extra NIB parts I never installed as well.
Odometer reads 102K miles, but the motor/tranny/drivetrain has 65K on it. For sale in other forums too so act fast. Buyer pays all shipping.
Asking $16,000 O.B.O. OR willing to trade for a 05 or newer Silverado or 05 or newer Tundra.
LOWERED PRICE: $15,000.
