I finally got around to posting my swap. I couldnt have done this by myself, first I want to thank all of my friends on LS1tech, Haighter(C.J.), and Rob at Strictly Performance.
Must know more:
What intercooler?
Fuel system?
Injectors?
Compression ratio?
Whats the specs on the cam?
Otherwise i call BS.
__________________ 2000 SS #15 Convertible
2001 K2500 LS Suburban
1999 Ford Interceptor CNG CNGForum.com
totally wrong... eaton will make no more than 500hp
Actually theres a guy porting them right now made 560/6xx with ported eaton,ported lower intake and bolt ons....around 660/6xx with a lil shot stock motor,heads ect.... But damn that Trans Am is sick!
Can you post a video of your ECS cam idle? I want to compare it to the EPP blower cam idle. I still don't know which cam to get...
I will try to get one, I was choosing between the same two cams but I googled "ECS cam" and chose it because of the drivability and since I dont drag race my car and am not trying to get every lil bit out of it. Plus it makes great power with no idling issues. I love it, my wife drove it this weekend with no problems and shes 6 months prego!!
I know the EPP cam makes tons of power too but I didnt want a lumpy cam since I was tired of having issues with my last big cam, I wanted something like a z06 type.
I will try to get one asap
Quote:
Originally Posted by johnzss
really nice car you got there!
Thanks
__________________ 2002 Artic White WS6
Full Umi Suspension: K-member,Upper and lower A-arms,Adj. Torque Arm,Adj. panhard bar,Lca's with relocation brackets, Bilstein/Eibach Pro Kit,ACPT carbon fiber DS,Kooks LT's, 2.5 True Duals w/ Sweet Thunder Chambered mufflers, CCW classics 18x11 all around Forged 6.0,205 AFR,+ D1@ 11lbs = 694hp 598 tq
very nice setup. Car is a freakin monster man!!!! You have any dyno graphs?? I want to see the power curve on this thing. Also a idle video of that ECS cam??? thanks.
__________________
2001 Camaro SS M6. Heads and Cam. TSP True Duals
431 RWHP, 391 RWTQ FQUICK
Thanks,
Here is the dyno sheet pic... I will get some vids of the idle as soon as the rain gives me a chance
Quote:
Originally Posted by ss.slp.ls1
Also what bypass valve are you using?
Pulley diameter?
Any reason you are not using a larger front mount intercooler?
The bypass I am using is one that Rob @ strictly was using on a personal car of his that he let me have.
The pulley diameter is a 3.55 I think
No reason for not using a FMI, its working fine now
