04-21-2009, 01:22 AM
#21 TECH Apprentice
how was the rubbing with the reg style zr1's? and are they 11" wide or wider?
__________________
94 Z28,Forged 383, AFR Comp 210s, Boosted, MS-II Stand Lone, 7xx with some luck
04-21-2009, 02:40 AM
#22 11 Second Club
1998 Chevrolet Camaro
Quote:
Originally Posted by
94m6Z28 how was the rubbing with the reg style zr1's? and are they 11" wide or wider?
If ur askn me, I removed the entire bumpstop and did a decent amount of pounding on the inner wheel well. Never rolled the lip, but should have. Mine almost stuck out and were tight, the 36mm offset I would think would basically stick out. I have pics of them on my old car. Let me see if I can dig them up. Had a nice shot from the back and they were right on the edge. O, also a adj. panhard is almost a must have in my opinion. Plus they rubbed a lil on my LCAs on both cars.
__________________
1999 m3
1999 NBM Z28 - Sold
1998 Black Z28 - Sold
04-21-2009, 02:44 AM
#23 11 Second Club
Found the pics of my old car. These were my old wheels, but same 335 Hoosiers. Same offset and width. 50mm offset and 11in. wide
__________________
1999 m3
1999 NBM Z28 - Sold
04-21-2009, 04:26 AM
#24 On The Tree
Gordo78 Cut sportlines? Good god how much ground clearance do you have left?
just the front where but it looked perfect now i got to lift her up because i got a 4'' down pipe going thur under the sway bar
__________________
turbo ls1 in norcal
04-21-2009, 04:39 AM
#25 On The Tree
jj_z28 Thanks. Sold the wheels now, and painted car all black. see sig.
youll see that black is hard to keep clean lol but when u just get it polished fully detailed thers no better color man
__________________
turbo ls1 in norcal
11-04-2009, 02:54 AM
#26 Launching!
jj_z28 Found the pics of my old car. These were my old wheels, but same 335 Hoosiers. Same offset and width. 50mm offset and 11in. wide
dam dude you had NO clearance with that body kit on....
__________________
Borla Exhaust, SLP Lid, Nitto 555r Drag Radial tires, Black Halo Projectors.
Dyno 323 hp 337 lb tq (Exhaust Only) 1/4 Mile: 13.5 @ 107mph
Click----> http://4thfbody.com
11-05-2009, 12:08 AM
#27 TECH Fanatic
1998 Pontiac Trans Am My Garage
18x10.5 wheels, with 335/30/18 Nitto DR's.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
