Click here to visit LS1Tech
Click here to visit Performance Trucks
Click here to visit Mod Motor Tech
Click here to visit Modern Hemi
LS1Tech Wiki
LS1TECH
Go Back   LS1TECH > CHASSIS, SUSPENSION, APPEARANCE > Wheels & Tires
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into LS1Tech.com, click logo to login
Old 02-03-2004, 03:19 PM   #21
Todd@AZPowerAndSound's Avatar
Trader Rating: 1
Send a message via AIM to Todd@AZPowerAndSound
theyll work all day long. 275s up front...285s will hit. 285 or 295 out back is fine, but BFH may be necessary
Todd@AZPowerAndSound is offline   Reply With Quote
Old 02-03-2004, 03:49 PM   #22
Trader Rating: 1
offset and backspacing are all relative. You can use either one to figure it out. Yes, theyll work
Old 02-03-2004, 03:55 PM   #23
FenixSS's Avatar
Trader Rating: 3
Send a message via Yahoo to FenixSS
Kewl, so 275x35xZR18 will be good with with these Z06s I found for sale, the +54 is ok, and no mods needed for fit or use. I'm gonna order them as soon as I get my tax return, thanks Todd.
__________________
2001 NBM Chevrolet Camaro SS, A4, Cloth, T-Tops (SOLD )
Performance Mods: K&N Airfilter, GMMG Exhaust, Z06 Pace MAF, MTI Carbon Fiber Lid
2000 Maroon Pontaic Firebird 3.8 V6, A4, Cloth, T-tops
Performance Mods: K&N Airfilter, More Coming...
FenixSS is offline   Reply With Quote
Old 02-15-2004, 12:18 AM   #24
01 ls1 z28 DA BRONX's Avatar
Trader Rating: 0
Send a message via AIM to 01 ls1 z28 DA BRONX Send a message via Yahoo to 01 ls1 z28 DA BRONX
does anybody run a 275/40/17 on a 17x11? on the other site, its listed as it will fit, but not on this site..
please let me know how this set up works, thanks
__________________
loudmouth, hooker 3.5" tips, pwr antenna, !side moldings, piaa HI/LO, grand sport( b/c ) 17x9.5, 17x11's, !c.a.g.s, sphon SFC, BMR tubular LCA, powershot filter, mobil 1, infinity speakers, taylor 10.4 wires, tr5 plugs, frost king lined
01 ls1 z28 DA BRONX is offline   Reply With Quote
Old 02-15-2004, 03:56 PM   #25
Moderator
LIL SS's Avatar
Trader Rating: 8
Please excuse my ignorance on this but I am lost
A 15x10 (7.5 offset) Draglite will fit on the rear with some grinding. But the offsets you mention above don't line up with that.
10.0" +38 to +54 mm 275, 285 (38mm = 1.5" / 54mm = 2") Given these are opisite to the 7.5 your still at 8-8.5" off set.
Is the above for direct replacement with no grinding?
If that be the case, a 7.0" +35 to +40 mm (1.37-2.0) 15" draglite would fit the front?
LIL SS is offline   Reply With Quote
Old 02-16-2004, 10:23 AM   #26
Trader Rating: 1
Dont confuse offset and backspacing as they really are the same thing.
17x10 + 38 = 6.99backspacing. Not 1.5" like you show below.
As far as drag applications go...I honestly dont have much knowledge on them. We do not sell them, and ive never really researched. I do believe the draglites rub based on the fact they are 15" and the barrel will contact the caliper.
Old 02-16-2004, 10:55 AM   #27
Moderator
LIL SS's Avatar
Trader Rating: 8
Todd, The 38 that you mention is mm correct? 38/25.4=1.49.. I'm still not getting the way your coming up with the 7" back space..
Old 02-16-2004, 12:13 PM   #28
Trader Rating: 1
yes mm.
backspacing =
(example) 9.5" rim with +56 offset.
Add one inch to rim, so now its 10.5. Divide that by two, 5.25. Add the +56 offset (2.20") 5.35 +2.20 = 7.55.
Your 15x10 above is a +51 offset
Old 02-16-2004, 04:39 PM   #29
Moderator
LIL SS's Avatar
Trader Rating: 8
Thanks Todd.
Old 02-29-2004, 12:22 AM   #30
Trader Rating: 0
OK... My turn
I just purchased a set of Y2K's (OE...i think...) 275/40 18's on 18x9.5's on the rear, 245/45 17's on 17x8.5's on the front...
My problem is the rear fitment... I have interference on the INSIDE of the rear wheels.. (tires are rubbing) but only on harsh bumps, or uneven road surfaces.......
I have room to the outside, so is there a spacer that looks nice asthetically that will resolve my problem?
Thanks in advance... Robert
BTW, vehicle is '02 Z28
HI85WH1 is offline   Reply With Quote
Old 03-01-2004, 08:52 AM   #31
Spin me Round Director
Xsta Z 28's Avatar
Trader Rating: 1
Exclamation
Quote:
Originally Posted by HI85WH1
OK... My turn
You have two choices:
BFH or spacer.
The areas where the tire(s) contact the inner wheel well can be massaged and reundercoated - commonly done.
Or get a spacer, size is up to you. 1/4" can typically be used safely with OEM lug studs. Once you hit 5/16" or greater longer studs will be required. H&R Springs make some really nice hub and wheel centric spacers specifically for the car.
Xsta Z 28 is offline   Reply With Quote
Old 03-01-2004, 05:40 PM   #32
Trader Rating: 0
Xsta Z 28,
I know GM used a hubcentric spacer on the 3rd gens... but they are a little thin for my taste.. I ordered two just to check fitment... I will check to see if H&R has a website...
I really hate to do the BFH mod on a car with a scant 11K miles... (you should have seen the look on my wifes face when I started talking about the hammer)
Note the car is otherwise completely stock... completely... not even the free mods...
Old 03-01-2004, 05:48 PM   #33
Trader Rating: 0
Hmm interesting,
seems they come with longer studs... dont know if I'll need them... but there is a dealer on island... and I just left work... they are about 2 miles away from my shop.
Thanks Xsta Z
Old 03-02-2004, 07:36 PM   #34
zacch123's Avatar
Trader Rating: 0
Default 275/40 17s on 17 x 11s
Saw a post while back but no response on this. Will the standard 01-02
SS Goodyear Eagle F1 275/40 17s work on a 17 x 11 wheel? Buying the wheels but no $$ for the wider tires at the moment. Would put 9.5s on the front and the 11s in the rear. The goodyear site hints that the tire will fit on 8.5 - 11 inch rims then mentions 9.0 to 11 inch...
Thanks
zacch123 is offline   Reply With Quote
Old 03-03-2004, 06:22 PM   #35
Xsta Z 28's Avatar
Trader Rating: 1
It could . . . a 275 is 10 13/16" wide, it's gonna look goofy but for the time being.
Old 03-06-2004, 11:11 PM   #36
Trader Rating: 0
I understand the offset...but what is the amount of backspacing that will work with our cars. I have seen rims listed with 5 and 6 inch backspacing, but nothing about offset. So what amount(s) of backspacing will fit?
Vogonuts98z is offline   Reply With Quote
Old 03-08-2004, 09:09 AM   #37
Trader Rating: 0
So supposedly a 18x8 with 5" backspacing will work...so a 18x9.5 with 6" backspacing...will leave me with 1/2" sticking out of the fender well???
Old 03-08-2004, 10:13 AM   #38
Trader Rating: 1
on 9.5 6 3/4" to 7.5" backspacing works and keeps you within the fender. Or +38 to +56
Old 03-17-2004, 11:09 PM   #39
2002 Pontiac Trans Am
BLASTER's Avatar
Trader Rating: 3
Send a message via AIM to BLASTER
What is the width of the WS6 rims? Do we have any stock offsets? I was considering getting 18"x9.5" in the front and 18"x10.5" in the back. What tires can I run safely with minimal rubbing? It says the wheel offsets are 65mm & 58 mm and suggests a 1/4" spacer for the rear. Does this mean that the wheel will stick out really far? Thanks
__________________
Kevin:Mods
2000 Silverado 6.0L 4x4: Magnacharged & 3" 304 SS duals
Exhaust & Intake | 230HP & 275 FT-LBS
Magnacharger w/ TTP tune | 305HP & 350 FT-LBS @ 7#s| 335HP & 380 FT-LBS @ 10#s
2002 T/A M6 WS6: Procharger cooming soon
Cam only | 415HP & 400 FT-LBS | No # yet | TTP Tuned | FM13 idle
Full bolt-on | 361 HP & 376 TQ | 12.323@112.65w/1.792
2000 Yamaha Roadstar
BLASTER is offline   Reply With Quote
Old 03-24-2004, 10:02 PM   #40
Ferocity02's Avatar
Trader Rating: 24
Send a message via AIM to Ferocity02 Send a message via MSN to Ferocity02
What is needed to fit 17x11" ZR-1's with 315's in the back. Car is not lowered. I was thinking +50mm offset, will this work, fender rolling? Are they direct bolt-ons? Thanks!
__________________
- Mike -
2001 Midnight Blue Silverado ECSB 5.3L
Mods:
Magnalfow dumped out the side, Line-X, Full Alpine Stereo, K&N, De-badged/trimmed
1999 Hugger Orange Camaro Z28 427ci LS1/7 - SOLD
Ferocity02 is offline   Reply With Quote
Tags
15, 17x10, 315, 53mm, 95x, aloyd, bolts, c5, fit, gto, image, replica, rims, size, style, tire, tires, wheel, z06
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
LS1TECH - Archive - Top
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
Advertising - Terms of Service - Privacy Policy - JOBS
