NIB custom ET Performance 245's
They're new 245cc runner ET performance cylinder heads with around $2000 worth of extra machine work and porting. They've been angle milled 1* so they're now a 10* cylinder head. The intake flange and bolt hole faces were all corrected for the angle mill, but you might need to run a little thicker intake gasket now to get the manifold fit back to where it needs to be. The combustion chambers have been totally overhauled and mirror polished, they measure 64cc's and are setup for a 4.030 bore. They have a custom 45* intake valve job cut on a 2.125 instead of the 2.08, and the exhaust is a custom 50* seat valve job cut at a 1.550. The intake ports have also been overhauled and now are up about 20cfm over what they were. The intake pushrod holes have also been sleeved to run a much larger pushrod on the intake side. I also have valves with these, they're 5/16 2.125's intake(backcut was changed from rev back cut to maximize flow), and 1.600 rev exhaust valves cut down to a 1.550 and put on a 50* seat to insure there was a nice thick margain on the exhaust side. Also these heads have been flowed on 2 seperate flow benches, a SF600 and a SF1020 Probench, both of which read a little low over average. The SF1020 reads about 10cfm low over Weld Tech's bench so on some other benches these things could flow upwards of 370cfm. $2200 plus shipping, need to get rid of these ASAP.
Flowed at 28* of water
.200 lift: 149cfm
.300 lift: 225cfm
.400 lift: 281cfm
.450 lift: 302cfm
.500 lift: 325cfm
.550 lift: 340cfm
.600 lift: 354cfm
.650 lift: 362cfm
.700 lift: 344cfm
Also i need to add that these were done to be a max effort ls1 head, not so much for a street car and would probably work best with a sheet metal or a single plane manifold.
.200 lift: 149cfm
.300 lift: 225cfm
.400 lift: 281cfm
.450 lift: 302cfm
.500 lift: 325cfm
.550 lift: 340cfm
.600 lift: 354cfm
.650 lift: 362cfm
.700 lift: 344cfm
Depends on the application but yea on anything other than a stock cube engine they're going to be significantly better. And sorry about the more than 1 ttt's, i wasn't aware that was a rule.
Originally Posted by SEBLS1
Are these better then the TFS 215 Heads?
anyone that tells you they aren't.. is full of crap. This head in stock form is probably THE best cathedral head out there, with addition al work done like these have..... even better.
