New Carb LS1 setup made 40 hp over LS6
In 2-3 weeks mass production begins on MSD LS1 Ignition system that will completely run an ls1 with a small box with a carburetor.
It plugs into the factory crank trigger/cam sensors and still uses a map sensor for vacuum advance function (hole in intake that the map sensor goes into). Also the setup mounts quick and clean. It has a 6-way adjustable timing advance curve on it, or plug in a laptop and its fully programmable.
He was explaining to me how they dynoed a mild heads/cam combo with a ls6 intake and made 420hp on the engine dyno and swapped off the ls6 for the msd setup with edelbrocks new "LS1 Performer RPM" dual plane intake and it made an additional 40 hp over the EFI setup.
He said the edelbrock intake is a fairly highrise that flows very well and makes awesome mid range and high rpm HP, which im suprised to hear. He has no experience with the new GMMP Single plane intake yet and didnt know much about it actually either.
Also on a bone stock engine they made like 23 hp over a stock ls6 intake.
Im gong to be doing a carb setup ls1 in a lt1 camaro bodystyle for a guy soon so ill be ordering a MSD ignition setup in a month when its available.
He said pricing is $250-$300 for MSD's setup.
I think that this ignition opens up a lot of doors for covnentional carburetor roots type supercharging on LS1 swaps also. The future is looking really good.
I got ahold of "mr clark" the engineer behind the ls1 setup and he said its not available seperate from the intake yet because they dont even have them in production yet. It will be sometime before its available seperate because at the moment they are only trying to make enough to keep up with the edelbrock intakes
Nate
I just got an e-mail back from Edelbrock about their intake. They told me Jegs is now carrying them and are selling the whole package for $833.00. I want to go this route this winter. Starting to pick up the pieces I'll need from here and there.
I figure $200 for a used cam. $500 for a short block. Give or take on that. $250.00 for a set of heads with aftermarket springs. Add the $833 for the intake/ignition system and you're well on your way. Sure there are incidentals such as exhaust manifolds/headers as well as the accessories and the necessary senors and coil packs. But that's not TOO much more. I think it will be the budget build everyone will be doing in the next couple of years. (at least those who had traditional SBCs under their hoods)
http://www.edelbrock.com/automotive/man_chevy_ls1.html
http://www.gmpartsdepot.com/store/pr...ategory_ID=11&
Now just which one to use?!?!?!?!
