Let's Talk WOT Vacuum!
Started out with 380hp/380tq. Worked with some PE, scaled my MAF down, and took out the knock retard and ended up at 400hp/400tq. This is a TR224 cammed car with Absolute Speed Stage II heads, LS6 intake and exhaust. The intake is a Home Depot sewer pipe special, since the LS1 lids wont fit on LT1 cars.
Oh yeah, this is a 99 LS1 in my 1994 Camaro.
Anyway, I am getting around 1.5 PSI (3 inches) of vacuum in the intake manifold at wide open throttle once the revs come up.
I start out just below one atmosphere when the gas is nailed for a dyno run, or a run on the street for that matter--around 14.2 PSI on most runs--but once the RPM climbs up, I dip down to around 13.2 PSI. Sometimes its a little more and sometimes a little less of a pressure decrease.
A friend said on carbed engines, the rule is nothing over 1" Hg of vacuum, and if you have more than that, it's time for a bigger carb.
So going by this rule, my 3.x inches of vacuum is probably holding me back. My theory is the Home Depot Ghetto special cold air induction is not up to snuff.
To prove this, I wanted to see some logs from you guys. Here is one of mine below.
So can anyone post up some results they have?
Thanks as always.
-Kyle
you things most don't see. Definitely an intake side
restriction in the pipe somewhere. A screened MAF will
be a bigger and bigger restriction, I believe quite nonlinear
as airflow goes up (all those channels will get highly
turbulent locally, lots of drag). But you could also have
something squirrely like a bellows / hose collapsing under
vacuum if it's too long / weak-walled, etc. 1.5PSI is a
huge drop, I see 0.1-0.2 tops (but only at 6000RPM).
My MAF is descreened/definned/sanded out. I removed my cone air filter and did a run and got the same results. I think this narrows it down to the small Home Depot elbow pipes that I used. Ah well, it's always something!
v/r
THE YAV
i can get up to 98-99kPa at 2700-4300rpm and 75%+ throttle
97 kilopascal = 14.0686606 pound-force/square inch (PSI)
99 kilopascal = 14.3587361 pound-force/square inch (PSI)
does that mean I have a problem somewhere? i have a slp lid+filter+granatelli maf+LS6 intake+smooth bellows. any comments?
question about your home depot special.... did you use 4" pipeing or 3"??
im just wondering if i could expect the same restriction. the angled pipe is a 4" - 45* lowes PCV pipe.... the elbow is a 4" to 3.5" (for the MAF) but i cant do anything about it.....
http://66.83.134.202/travis/LS1%20pics/Engine2.JPG
http://66.83.134.202/travis/LS1%20pics/CAI.JPG
http://redhardsupra.blogspot.com/
lemme know what you think
