New C6 Z06 Dyno numbers**LG Motorsports cam results with LG Headers, No tune
Old Jan 2, 2006 | 10:56 PM
LG Motorsports's Avatar
Default New C6 Z06 Dyno numbers**LG Motorsports cam results with LG Headers, No tune
Hi Guys,
Here are the latest dyno numbers for our latest Cam test. We took the already good cam that we had for the Z06 and changed it up some to come up with the following results.
546.6 rwhp 505.7 rwtq with LG Cam and LG Pro Long Tube headers.
We are working on our Final specs for our G7X-2 cam for the new Z06. And this looks like where we will stop for the X-2 cam. then on to the G7X-3 amd upward.
Of course we are using our LG Pro Long Tube headers which are still the standard of the Corvette market. And these numbers are WITH CATS.
We also use fully welded Merge collectors to avoid air leaks when slip on collectors are welded on. Slip on collectors will leak in the 30% of tubing that can not be welded. This will fool your 02 sensors with air infiltration, so we supply our headers with fully 360 degree welded Merge collectors.
We are still without tuning for a couple more weeks but that should just help to clean up the numbers and help the final results even more.
The graph has before numbers are from our 540rwhp 489rwtq cam. Our goal was to excede 500 rear wheel torque, and you can see that we did easily. in the process we picked up another 25 ft pounds of rear wheel torque at 2800 rpms and 6 more rwhp.
This is also with the same "air filter mod" which means that the stock filter is removed for now until we get a good Cold Air induction for the Z06.
Also remember that this car dynoed stock at 443rwhp so we are at over a 100 hp gain.
thanks
Lou Gigliotti LGM
Old Jan 2, 2006 | 11:04 PM
Quickin's Avatar
HI Lou,
Whats your best guess at what the LS7 will put down with what you've done already and a tune?
Old Jan 2, 2006 | 11:18 PM
good question. The tune should be worth at least 10 but you never know. The heat affects the power more in this car than normal, so the factory PCM has many adjusters inside to pull timing etc.
Hopefully we will have the tuning software in a couple more weeks.
thanks
Lou G
Old Jan 3, 2006 | 04:43 AM
HartAttack's Avatar
Very impressive. How much bigger is this cams spec from the other one?
Old Jan 3, 2006 | 05:29 AM
JMBLOWNWS6's Avatar
Awesome #'s. Im curious what tuning software you are going to use.
Old Jan 3, 2006 | 08:39 AM
Reckless's Avatar
Super Moderator
Nice job Lou, how is the air/fuel with the stock tune?
Old Jan 3, 2006 | 09:09 AM
Nine Ball's Avatar
LS1Tech Co-Founder
Nice results Lou, I'm sure you can't wait to build an all-out NA setup using that LS7. I'm sure we will see quite a few at 600+ rwhp once tuning becomes available, and more aggressive cams are used.
Solid roller LS7 anyone?
Old Jan 3, 2006 | 09:21 AM
Blown SS's Avatar
Nice !!!
Old Jan 3, 2006 | 11:44 AM
BurnOut's Avatar
Nice!! Does it still idle nice and smooth like the first cam??
Old Jan 3, 2006 | 12:46 PM
Forced370GTO's Avatar
wow that is incredible
Old Jan 3, 2006 | 01:12 PM
383ss's Avatar
freak'n amazing
Old Jan 3, 2006 | 03:58 PM
MeentSS02's Avatar
Kleeborp the Moderator™
Are you still using stock valvesprings?
Old Jan 3, 2006 | 06:54 PM
NO.
LG
No, Better. Really.
LG
Old Jan 3, 2006 | 07:05 PM
pdd's Avatar
pdd
WOW-GREAT JOB LOU
Old Jan 3, 2006 | 08:48 PM
John B's Avatar
Very impressive Lou! Congrats!
I could be game! Or maybe a G7-X4!
