QTP HV Merge Header LEAKING BAD
Old Mar 31, 2008 | 11:46 AM
White_Hawk's Avatar
Default QTP HV Merge Header LEAKING BAD
Here is another post with some pics:
https://ls1tech.com/forums/generation-iii-external-engine/868073-got-my-qtp-lt-s-today.html
Mine leak so bad that I am overcome by fumes if I am driving with the windows up and the vent on. I either have to get rid of them or fix them, and they perform too well to get rid of.
Since QTP didn't return my email, has anyone got any repair ideas? I was thinking of braizing them or even silver solder. It is too tight to get a torch head back there (which is why they aren't welded in the first place fyi), so welding is pretty much out. Anyone?
-Geoff
Old Mar 31, 2008 | 06:32 PM
ls2 bait's Avatar
where are they leaking?
Old Mar 31, 2008 | 07:06 PM
White_Hawk's Avatar
There are pics in the last thread of that link I posted. I will get some pics of mine up tomorrow.
Also, I just noticed I posted in the wrong forum. Could someone move this to external? Thanks.
-Geoff
Old Mar 31, 2008 | 10:27 PM
White_Hawk's Avatar
Here is a pic from the previous post. I will get pics of mine up tomorrow.
-Geoff
Old Mar 31, 2008 | 10:46 PM
BLACK2001SS's Avatar
that looks like it could be fixed from that picture. But if I was in your boat I'd take it out and take it to a shop and have them fix it. I think you need to have wire to weld stainless so I'd just call around I dont know what qtp would do for you but I'd try to get ahold of them thats a defect in my book.
Old Apr 1, 2008 | 02:13 AM
GMmexican's Avatar
-Geoff
mine have a gap like that in the same exact place......i think ill be taking them to a shop to get them fixed, i havnt installed them yet
Old Apr 1, 2008 | 08:11 AM
The Alchemist's Avatar
UNDER PRESSURE MOD
You could always try some JBweld or some other high temp epoxy.
Old Apr 1, 2008 | 08:29 AM
bluehawk2's Avatar
Why will QTP not fix their headers?................. it is an obvious defect from them.
Old Apr 1, 2008 | 08:59 AM
ls2 bait's Avatar
because of the 100 they sell a month how often do u hear about this? once every few months if that. mne werent welded either in that part and dont leak.
Old Apr 1, 2008 | 10:16 AM
White_Hawk's Avatar
They haven't told me they won't fix them. I would sure like to hear their response on this though. I have had them for about year. I chased the leak all over including two different y-pipes, a dozen band clamps (at $10 a pop), and six tubes of RTV Copper. Then I find out the header itself is leaking.
The problem is, you just can't get in there and get a welder on them. I thought I might be able to get a Oxy/Acet torch in there and melt something in. Just looking for some ideas.
-Geoff
Old Apr 1, 2008 | 10:17 AM
White_Hawk's Avatar
That is a good idea. What other options are there? Not that I have anything against JB weld.
-Geoff
Old Apr 1, 2008 | 10:46 AM
RoDan's Avatar
I like the JB weld idea, or some of that metal epoxy that is in the clay bar that you have to knead to active. You could pack the crap out of the header collector with some of that stuff...problem is I have no idea what kind of temps it can withstand. I believe that stuff is called "Quicksteel" or something like that.
edit: looks like it is good to 500 degrees... http://www.dual-star.com/index2/Serv...poxy_putty.htm
Old Apr 1, 2008 | 10:54 AM
03Sssnake's Avatar
My QTPs were not welded on that primary either, but no leaks to date..KNOCK ON WOOD. I noticed that about 1/4 of the weld was incomplete before putting them, but it looks like my fitment was just tight enough to seal.
Old Apr 1, 2008 | 12:16 PM
I dont know about JB weld I dont think that its made for high temp like that I could be wrong but I wouldent trust epoxy on mine, and I have used JB weld on alot of stuff it works great.
Old Apr 1, 2008 | 01:31 PM
GMmexican's Avatar
wouldnt the heat expand the metal and seal the leak on its own?
Old Apr 1, 2008 | 03:43 PM
White_Hawk's Avatar
I think it would if it weren't welded at all, but it is about 2/3 welded and it can't expand the whole diameter.
-Geoff
Old Apr 1, 2008 | 10:05 PM
White_Hawk's Avatar
Here is the pic of my passenger side which is leaking the most. Driver's side looks similar to the other pic (came out too blurry). My camera keeps focusing on the first thing in the line of sight.
-Geoff
Old Apr 1, 2008 | 11:12 PM
GMmexican's Avatar
did u get the batch that came with no qtp badge and a weld on the primary?
Old Apr 2, 2008 | 10:35 AM
Patrick G's Avatar
LS1 Tech Administrator
Moved from internal section.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
Old Apr 2, 2008 | 04:31 PM
White_Hawk's Avatar
They have a badge on them, so I don't think so. It looks to me like these are not supposed to be welded. They fully weld the first two, but they can't weld the inside of the last two. If it was a tighter fit, it wouldn't leak, but the slip fit wasn't that tight and now there is a huge gap.
-Geoff
